Old 04-19-2011, 02:03 PM
kirkbross's Avatar
kirkbross kirkbross is offline
Default Overdub monitoring level conundrum?
Any tips for boosting the volume of a record track when overdubbing on a fully-produced, mixed song without having to crank the record track's fader to "crackly" levels or bringing down ALL the other tracks?
I am always having this issue: I track and overdub a song and then do a nice mix with automation and have everything sounding great. Then I decide to overdub another part and I can never get my record track loud enough in the cans without either cranking the fader to +12 and/or bringing ALL the other tracks down 10dbs or so. Cranking the record track's fader way up usually results in a crackly sound and bringing all the other tracks down is just a pain to revert and destroys the insert levels anyway (resulting in a more verby sound usually).
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave.
Old 04-19-2011, 03:59 PM
jbasil jbasil is offline
Default Re: Overdub monitoring level conundrum?
How about bouncing down a mix, putting it on a new track and muting the originals and make the master fader receive from anything but 1 & 2, which is this track (and everything else. It's easier than bypassing 4 plugins). Set up overdub and lower ref mix volume.
Old 04-19-2011, 05:27 PM
The Dougfather The Dougfather is offline
I've found it really good practice to set up an Aux track at the start of a session and call it Mix Bus or the like. I then route all of my tracks to the mix bus and then route the mix bus to Analogue 1-2.
In this scenario you could pull down the mix bus aux and if you route the over dub track directly to Analogue 1-2 you can easily find the balance without cranking everything up. Having a mix bus also helps down the line with printing because it means you don't have to hunt through your session changing the i/o, create a single send to a new audio track and your done.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 04-20-2011, 02:51 AM
Ben Jenssen's Avatar
Like dougfather, I also make a aux as my master fader first thing. One more reason: aux plugins is not post-fader like the analogue-out-master plugins are. As for the OP's issue, yes, route everything that's now going to analog outs to an aux. (Select all these tracks hold down option-shift and the change you do on one will affect all the selected tracks.
Mac mini M2 base model, 16GB RAM. MacOS 13.2.1.
PT Studio 2023.3.
2 x Artist Mix, SSL UC1, Avid Control on iPad.
input monitoring level and record level different Jason1 macOS 8 12-07-2014 10:06 AM
Record monitoring level different from Playback monitoring level. sonicflwr macOS 1 03-09-2012 10:05 AM
Question on mix bus level and my monitoring level dilemma bukman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 10-20-2009 05:06 PM
Overdub / Punch Ins - Double Monitoring Workflow Issues geelo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-16-2008 11:31 AM
Output level/Master Fader conundrum... jensen5 Pro Tools M-Powered (Mac) 2 05-30-2005 10:41 PM
