Hard Drive adding distortion
I'm running Pro Tools M-Powered 7.0 on a computer I built and it worked fine until I put in a new hard drive. The sessions still run from my old hard drive without a problem, but when I try to run them from my new Seagate Baracudda drive, I get a destorted clipping noise that plays back with my audio. It only does it in Pro Tools though. When I bounce tracks down and listen to them through windows media player or musicmatch they sound fine.
I was wondering if anyone knew if there are any problems with Pro Tools compatability with PCI host cards. I got a Vantec Serial ATA 1.5 PCI host controller to connect my new hard drive. I've already moved it to a new slot and messed with all the PCI latencies and my Delta 44 latencies and nothing has helped get rid of the distortion. Anyone got any ideas? |
Re: Hard Drive adding distortion
Is your PC power supply powerful enough ? soundcards, PCI adapters, fast disks etc. tend to draw a lot of power.
Although this may not be the problem, it is worth checking, notably if your mains voltage is a bit weak.
Mark Haliday Engineer, Mixer, Writer, Teacher Pro Tools Ultimate HDX Mac Pro 2013 & Chassis |
I have a 400watt Antec Power supply that I though should be enough. I don't know though. Also, sometimes when I boot up, the Vdd voltage drops into the red but usually jumps back up. I don't if that could be why its adding distortion.
The funny thing is, I only get the distortion in Pro Tools, any other programs that I listen to music with work fine off of that drive. |
Adding a second Hard Drive 001/XP/LE6.4 | Gretsch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-26-2007 09:25 PM |
Adding hard drive to 1814 | hjorte | Pro Tools M-Powered (Win) | 5 | 01-03-2006 05:16 PM |
Adding first hard drive | bonedaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-02-2003 07:31 AM |
Adding hard drive to B&W Mac G3 | davidp158 | Pro Tools TDM Systems (Mac) | 8 | 01-14-2002 02:35 PM |
adding 2nd Hard Drive | seandenley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-12-2001 10:01 AM |
