Old 09-01-2002, 02:56 AM
GS-DK GS-DK is offline
Default External effects
Hi
What's the best way to route tracks and (if possible) if you want to take the audio through an external effect like a Kaoss-Pad? I will like to process the audio (already recorded) and bring it back into PT. Any setup suggestions?
thank you
GS-DK
Old 09-01-2002, 03:08 AM
Bastiaan Bastiaan is offline
Default Re: External effects
Send the audio to a hardware output (lets say stereo 3&4 ) instead of a normal output.
Create a channel with the input set to that inputs 3&4.
Connect your gear to outputs 3&4 and send it back into inputs 3&4.
Record-enable the new track, and start recording.
You probably will encounter latency, so after you recorded you may want to nudge the newly recorded audio to the left a bit.
I am not sure, but it could be that this method works with low-latency mode ON....
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 09-01-2002, 09:04 AM
Hi
I want to do this on M-box - is it possible?
GS-DK
Old 09-03-2002, 02:13 AM
to the top
Old 09-08-2002, 09:02 PM
La Flange La Flange is offline
You'll have to use the Mbox S/PDIF i/o, which means you'll need an outboard D/A and A/D converter if the effects unit doesn't have a S/PDIF interface. The ART Dio is a cheap a/d d/a solution.
Old 09-10-2002, 06:32 AM
DigiTechSupt's Avatar
-Although it is possible to create a Hardware Insert using MBox hardware, it is not the ideal system to set this up due to its limited I/O combinations. Since S/PDIF Mirroring is always active with MBox, all tracks outputting audio will be routed into the EFX unit (via S/PDIF).
With that being said...If you want to create a hardware insert but do not want to process the entire session, you will have to mute all unwanted tracks and print the the output of the EFX unit (i.e. the processed result of the desired tracks) to another audio track to be used in the session.
Brent
Avid Audio Tech Support
Support FAQ
External Effects solivan2010 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-15-2010 08:52 PM
external analog buss effects buss effects patching bryanbassett Pro Tools TDM Systems (Mac) 10 10-07-2004 03:39 PM
External Effects surfengine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-12-2004 11:45 AM
External Hardware effects VS plugin RTAS effects boogiewoogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-19-2003 06:25 PM
external effects major_thom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-08-2001 12:29 AM
