Old 08-23-2016, 10:46 PM
Yehudi Yehudi is offline
Default two Audio Interfaces in Pro Tools 12.5.2 [SOLVED]
Long time ago, I saw somewhere a way to use 2 Audio-Interfaces in Pro Tools. So I use my Eleven Rack and the Internal Output from the Mac Book Pro. The Internal I used for my headphone Mix, and the Eleven Rack for the Headphone for the singer. It was working fine until I put the language from german to english, and the preferences was gone. I couldn't make the preferences again, even that only one interface is working. But with the time Machine Backup I get the preferences back, but only the eleven rack is working. I don't get the internal interface back. I made all the stuff one or two years ago with Pro Tools 10 or 11. I'm stand there like a duck in a thunder storm. Did they change something with Pro Tools 12 or 12.5.2, that it's not possible to create that again?
MacBook Pro Quad 2,3Ghz i7, 16GB Ram, 64Bit
Pro Tools 2018-12, Logic X, Cubase 9.5
Eleven Rack
Old 08-24-2016, 02:07 AM
Default Re: two Audio Interfaces in Pro Tools 12.5.2
solved:
OS X -> Audio Midi Setup -> Audio
Pro Tools Aggregate I/O
- Output (intern)
- Avid Eleven Rack
In Pro Tools
Setup
- Hardware -> Pro Tools Aggregate I/O
- Playback Engine -> Pro Tools Aggregate I/O
- I/O -> Pro Tools Aggregate I/O
- Monitor only on Mainoutput
Eleven Rack
Old 10-22-2016, 03:51 PM
epic41 epic41 is offline
Thanks for posting the solution!!
Compatible Pro Tools 12 Interfaces [solved] HuddUni Pro Tools 12 26 10-24-2016 05:26 PM
Using 2 Audio Interfaces With Pro Tools 11 mhier FireWire & USB Audio Interfaces (Win) 1 10-18-2013 07:23 AM
Pro Tools LE and M-Audio interfaces sighermike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-04-2010 06:43 PM
Pro Tools 9: Audio Interfaces pearl_drummer Pro Tools 9 4 11-11-2010 09:33 AM
Can Pro Tools LE run with M-Audio Interfaces Consuption Pro Tools M-Powered (Win) 3 06-07-2009 10:15 PM
