Old 06-17-2013, 05:30 PM
Irl Sanders Irl Sanders is offline
Default Key Command to bring AudioSuite window to front?
I'm trying to write a QuickKey Macro that will do some things inside an open AudiSuite window, that involves clicking in the AS window, clicking in the Edit window, then clicking back inside the AS window. Does anyone know a key command that will make the AS window the frontmost window? I know I can do mouse clicks to achieve this, but find key commands to be far more reliable. Thanks.
Irl Sanders
Music Editor
LA, CA, USA
Old 06-17-2013, 05:33 PM
Drew Mazurek's Avatar
Default Re: Key Command to bring AudioSuite window to front?
Have you tried Command ~ (tilde)?
www.drewmazurek.com
Old 06-17-2013, 05:55 PM
Yes, but AS windows don't respond like Finder windows
It's also lame that ALL open AS windows are now named "AudioSuite" whereas in PT9 they were titled "Audio_Suite (plus plug in name)". A number of useful window manipulations have gone away because of that.
Irl Sanders
Music Editor
LA, CA, USA
Is there a shortcut to bring up the Spot Dialog window? hirac Post - Surround - Video 6 03-15-2018 05:18 PM
Is there a key command to bring the new piano roll editor pane up? Ru_C Pro Tools TDM Systems (Mac) 2 03-14-2011 11:04 PM
Can you bring an audiosuite plugin under d-command surface control paulroberts ICON & C|24 0 03-22-2010 01:24 PM
Bring edit window forward? cogan Tips & Tricks 4 01-19-2007 01:02 PM
Bring selected region to the front / back 6.7 ???? SuperReverb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-09-2005 02:20 PM
