Here it goes, I have a Mbox 2 mini and I recently got a Win 7 64Bit computer, I have tried to install PT 8. I've gotten it to install but then it said there were clock issues. I unistalled it, reinstalled the program and now when it's loading it just freezes and gives BSOD. I have attached my Sandra Report. Hope this helps. If I did not give enough information, please feel free to kick me in the shins. Thanks in advanced.
SiSoftware Sandra Computer Model : Acer Aspire 5742G Workgroup : WORKGROUP Host Name : Flashmcclain-PC User : Flashmcclain Processor Model : Intel(R) Core(TM) i5 CPU M 460 @ 2.53GHz Speed : 2.66GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 4 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Acer Aspire 5742G BIOS : Acer V1.04 08/11/2010 Bus(es) : PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.87GB DDR3 SO-DIMM Chipset Model : Acer Core (Auburndale/Havendale) DRAM Controller Front Side Bus Speed : 1x 133MHz (133MHz) Total Memory : 4GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Kingston ACR256X64D3S1333C9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ACR256X64D3S1333C9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : NVIDIA GeForce GT 420M (64 SM5.0 1GHz, 1GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GT 420M (64SP 2C 1GHz, 993.4MB) CUDA Processor : NVIDIA GeForce GT 420M (64SP 2C 1GHz, 993.4MB) Compute Shader Processor : NVIDIA GeForce GT 420M (64SP 1GHz, 993.4MB) Storage Devices WDC WD5000BEVT-22ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 466GB (C:) MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890AS (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (D:) Disk : 881MB (E:) Logical Storage Devices SYSTEM RESERVED : 100MB (NTFS) Acer (C:) : 452GB (NTFS) @ WDC WD5000BEVT-22ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) PQSERVICE : 14GB (NTFS) Hard Disk (Q:) : N/A Optical Drive (D:) : N/A @ MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890AS (SATA150, DVD+-RW, CD-RW, 1MB Cache) 20071228_1508 (E:) : 881MB (CDFS) @ Disk Peripherals LPC Hub Controller 1 : Acer HM55 LPC Interface Controller Audio Device : Acer P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : Acer 0BEAh Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Disk Controller : Acer P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : Acer P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Acer P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet Wireless Adapter 1 : Atheros AR5B97 Wireless Network Adapter (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : Off-Line Battery No 1 : 33% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.8 |
Just plain PT8? 8.0.4 is the first version of Pro Tools supported on Windows 7.
Download the upgrade here. That, I think, is your main problem. I would disconnect the hardware, uninstall Pro Tools and the drivers and restart. Then install PT8 again without hooking up your hardware, then install the 8.0.4 upgrade and hook up the hardware when prompted by the install. You will probably want to install 8.0.4cs2 after that as well. ![]() Now for some issues about your computer that may be problems once you get it installed and running: Quote:
You will need to disable that while using Pro Tools.
Thanks for the quick reply first and foremost!
I have a laptop with only USB and no FireWire connections. I imagine this could be a problem for hooking up a separate drive? I had Win XP 7.4 working on 7200RPM machine and it worked flawless, i'd still be using that computer if it didn't burn out. Also, i can't just update the hard drive to a 7200rpm one and that will solve the problem? I know I will need to according to the link you gave me. Thanks! |
Or could I just partition the Hard Drive?
![]() Quote:
You may want to consider upgrading to Pro Tools 9. The audio drive requirements have changed for Pro Tools 9, and USB2.0 drives are now approved/supported/recommended for Windows laptops. No. Recording to the system drive is not supported either. It needs to be a separate physical disk.
Eleven rack expansion pack install sw not working on win7 64bit !... | KC70 | Eleven Rack | 12 | 02-28-2012 05:46 AM |
Installing Mbox2 Win7 64bit drivers WITHOUT Protools 8 - Have you done this? :-) | grasta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 02-25-2011 07:23 PM |
new PT 8.04 install on Win7 64bit | muziqman | Eleven Rack | 4 | 01-04-2011 02:39 PM |
help with 64bit win7 install | markblasco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 06-14-2010 06:09 PM |
Mbox 2 Pro no sound in Win7 64bit | jasonspboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-23-2010 11:13 AM |
