When starting Pro Tools 8.0.4 the AIR effects are not listed in the Audio Suite list, only in the RTAS lists. I tried to reinstall the AIR effects without an effect on the situation. Is that a bug? I need these effects. What is to do?
I don't recall ever seeing the AIR effects in audiosuite... I could be wrong, but I've never used them from there. Pretty sure they are only available as inserts.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
I quite often used them from Audio Suite to save CPU power.
Well then apparently I am experiencing the same bug...?
Impossible.
They were NEVER AudioSuite or TDM for that matter - only RTAS. Are you sure you are not referring to the DigiRack effects? |
I found the plug-in guide and it talks about a set of RTAS-plugins. I guess you are right. I was quite sure about it. Thanks for your postings.
TDM versus RTAS effects - the same? | Mike Greene | Pro Tools TDM Systems (Mac) | 3 | 02-01-2008 05:57 PM |
Rendering effects using RTAS ? | Poignant | General Discussion | 5 | 02-12-2007 11:21 PM |
RTAS Effects on AUX workaround? | Shan | Pro Tools TDM Systems (Win) | 2 | 07-16-2005 08:44 PM |
External Hardware effects VS plugin RTAS effects | boogiewoogie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-19-2003 06:25 PM |
No sampletank bpm effects in rtas only | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-08-2002 09:05 PM |
