Old 04-05-2010, 10:55 AM
Walker0509 Walker0509 is offline
Default Route Logic Audio Into PT Session?
I figured out how to route MIDI in PT MIDI tracks into Logic via the IAC Bus. To complete the circle I need to get Logic's output back into a PT track. Does anyone on here know how to do this? It seems that PT audio tracks will only accept as an input one of the physical inputs that exists on the Digi interface. As a workaround to this, I found and installed an app called SoundFlowerBed which is supposed to be capable of routing audio between applications. I just don't have a handle on how to get it to do this. The virtual channels the SoundFlowerBed app creates don't show up in PT.
Old 04-05-2010, 11:12 AM
lincol1 lincol1 is offline
Default Re: Route Logic Audio Into PT Session?
you'll need to use physical inputs.
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 04-05-2010, 11:32 AM
Thanks. Its so weird that amongst all of the abilities of these apps there doesn't exist even one way to route audio between them.
Old 04-05-2010, 12:36 PM
nst7 nst7 is offline
You may be able to use the output of your computer, since it functions as a spidf out, into the spidf (or maybe the adat set to optical) on your PT interface. You may need a special cable, and it would only be 2 channels (you could record things 2 channels at a time until you have everything).
Old 04-05-2010, 03:06 PM
Skyflash Skyflash is offline
I did a little while back with PT 7.4 and Mainstage and it worked well with my Project Mix.
The drivers allow sharing between Logic and Pro Tools and I just simply patched a set of
1/4" cables back into a pair of inputs. Set your levels and go.
2006 'Blackbook' Core Duo 2.0 ghz.
2 gig OWC RAM
10.5.8
PT Mpowered 8.04, Logic 9.1.1
Waves SSL,Omnisphere,Korg Legacy Digital
Absynth 4, EZ Drummer
Project Mix I/O w/ Black Lion Mod
Axiom 61,25, Korg Nano Pad
How to route USB audio into Pro Tools Armando Pro Tools TDM Systems (Mac) 8 06-12-2018 07:43 PM
Loops and sounds (can not find the route in the session) elsanto Pro Tools 10 4 09-10-2012 07:59 PM
Can I open Logic Audio session file with pt? kinghand Pro Tools TDM Systems (Mac) 10 12-10-2004 09:03 AM
Can't route CPU audio thru I/O! mrdecibel Pro Tools TDM Systems (Mac) 2 05-28-2004 05:04 PM
How do I transfer a session from Pro Tools to Logic Audio? jjelduce Pro Tools TDM Systems (Mac) 2 05-01-2001 09:54 AM
