Old 11-20-2009, 08:50 PM
geekindapink geekindapink is offline
Default Pro tools crashes on load screen
This morning I was editing a song in pro tools using reason as a rewire slave and everything worked normally. I closed down both programs and went about my day, now I'm trying to load pro tools and it freezes on digirewire.dpm. I can't seem to locate the unused plugin folder to see if deleting that would help. Anyone got any ideas?
Mac Pro quad core xeon
6 gb ram
PT LE 8.0.1cs1
Old 11-20-2009, 09:18 PM
samwise samwise is offline
Default Re: Pro tools crashes on load screen
Its in
Library>Application Support>Digidesign>Plug-Ins (Unused)
Although, I'm pretty sure its in the Plug-Ins folder.
Move the plug out of there (to anywhere you want) and Pro Tools will load. BUT you can't run Rewire without it. I had the same problem and a simple Pro Tools re-install did the trick for me.
Old 11-23-2009, 10:10 AM
DigiTechSupt's Avatar
http://www.digidesign.com/index.cfm?...&categoryid=34
Avid Audio Tech Support
Support FAQ
Old 05-17-2010, 11:02 AM
alschnier alschnier is offline
having same issue. already clean reinstalled 2x, w/ no results. I want rewire to work. not willing to trash it, to run PT. I'd sooner keep using DP.
any other options?
Old 05-17-2010, 11:15 AM
went to: library> application support> propellerhead folder: removed both melodyne files. got past launch! just synced w. Reason & worked great.
Pro Tools 8.0.3 Won't Load. Hangs on loading screen kfoody Pro Tools M-Powered (Win) 3 01-03-2010 01:10 AM
Pro Tools crashes on LOAD UP! (after format) Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-08-2009 11:55 AM
pro tools le 7.3.1 cs 5 session load up crashes streetcorna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-14-2007 06:03 AM
When I load pro-tools it crashes docholliday 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-24-2005 09:43 AM
When I load pro-tools it crashes docholliday 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-24-2005 07:57 AM
