Old 12-12-2001, 03:59 PM
Mike Caviezel Mike Caviezel is offline
Default Direct Connect cpu 6031 error
Hi, everybody. I just upgraded from A beige g3 233 to a new (to me, anyway)G4 450 AGP, with 384 meg of RAM and OS 9.1. I'm using a mix plus system with ATTO epci dc card and 2 18 gig external glyph drives. PT 5.1, and the 128 version of direct connect that shipped with 5.1.
On the beige G3, everything worked like a champ. Now, on the new G4, everytime I run an instance of a DirectConnect plug in (I use Unity DS-1), I get horribly stuttered playback, along with a flashing message in the DirectConnect plug-in window that says "Something is using too much CPU time. Error -6031". I imagined this was pci bus related, so I made sure all my ATTO settings were at the recommended 20 (10) setting, disabled all my ATI extensions, and rebooted. So far, nothing has helped. I'm starting to get desperate, as I can't even get through to phone tech support at Digi (I keep geeting the 'sorry, can't connect your call right now' message. After I've entered my credit card info, of course.)Do anybody know what is causing this? Thanks for your help.
Mike Caviezel
Old 12-13-2001, 07:11 AM
DigiTechSupt's Avatar
Default Re: Direct Connect cpu 6031 error
-This error could be caused due to your drive formatting. For ATA drives, use Apple Drive Setup. For SCSI, use ATTO EPT v2.3.2.
-In addition, trash the DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and relaunch Pro Tools.
-As a matter of troubleshooting, install the 512 buffer version of DirectConnect v5.1 and see the system behaves any differently.
Brent
Avid Audio Tech Support
Support FAQ
Old 12-13-2001, 10:46 AM
Aha! Trashing the Digi prefs seemed to do it. I haven't yet installed the 512 version of DC, but I'll try it. Thanks.
Mike Caviezel
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O booyaaslam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-04-2002 01:55 AM
DIRECT I/O ERROR 6031 WHEN USING LOGIC STEREO STORMTROOPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-19-2002 07:45 AM
"Error Code -6031 was returned by the Direct I/O driver." Groovy C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-28-2001 08:32 AM
error code 6031 using direct i/o in logic graphite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-29-2001 07:08 PM
direct connect troubles error -108 latenights 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-09-2000 08:38 AM
