#21
Re: MacBook Pro M1 MAX - Pro Tools Performance?
I have a very simple benchmark Pro Tools session where I have got a Softube Console 1 (K series SSL), Fabfilter Pro-Q 3, Fabilter Pro-C2, Waves Abbey Road Plates, Izotope Ozone 9 and Fabfilter Pro-L 2 across every track. Perhaps you have the same plugins, or I can make an alternative session with the plugins that you do have? |
#22
#23
#24
hey all
i do a lot of heavy duty mixing with all the plugins (and more) that OP is asking about. i just bought an M1 Max. i can report that although the CPU is amazing and efficient, the plugins do not all like to be in rosetta and i experienced a lot of crashing. if you are a professional, i would strongly advise to NOT try this. i am returning the M1 Max and bought a used 2019 i9 16 inch. i definitely do not recommend running professional, on the clock, sessions from an M1 or later until both pro tools AND the 3rd party plugins fully certify. i had a lot of weird bugs, some of which were very very scary (uad plugins loading, seeing the UAD device, but passing only dry audio, for example) hope that helps |
#25
#26
#27
What is unclear , is how much iLok actually factors into this.... As I understand it iLok does not run natively on Apple silicon and requires Rosetta . So I am wondering if iLok is not the actual problem and if Pace would get it working natively on Apple silicon then Apple the OS's might just run natively and many issue would go away ???????????????
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#28
this may be true, but there is no way to run Big Sur on an M1 Max. so Monterey and M1 Max are essentially married. you can't downgrade an M1 Max machine to Big Sur. If anyone has successfully done it, please post steps! i tried all the things
#29
Not possible unless you have Alpha build available.
#30
I find it strange that Apple would effectively shut out the majority of the professional music community.
Simply allowing for rollback to Big Sur is all that would be needed to bridge the gap. |
Macbook Pro 13" vs. iMac Pro |*Pro Tools Performance | Meads | macOS | 0 | 11-14-2019 11:51 AM |
MacBook Pro i9 throttling and performance | Guitarman002 | macOS | 42 | 02-01-2019 11:20 AM |
Macbook 12" + Pro Tools 11. What performance can I expect? | tobbenos | macOS | 4 | 07-15-2017 04:21 PM |
Performance of Macbook (Pro) | rmccam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-19-2007 10:05 AM |
macbook performance | Bologma | Pro Tools M-Powered (Mac) | 12 | 04-16-2007 09:16 AM |
