Old 06-06-2022, 07:24 AM
Talisker Talisker is offline
Default AAE error 9095 after installing PT studio
I just installed PT studio ( my setup is in the signature). Most sessions work fine, only on one session I get an AAE error 9095. And that error is not even listed in Avid*s error list. Anybody know this error ?
Thanx
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 06-14-2022, 11:35 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: AAE error 9095 after installing PT studio
When exactly do you get the error - When you open the session? Upon playback? Try disabling all plugins (or open the session with plugins disabled) and see if you can play with no errors. Then start enabling plugins and see if at some point the error occurs - when it does, the last plugin you enabled is the likely culprit, if it's a plugin issue - which I'm guessing it is.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 06-15-2022, 12:46 AM
I can't even open the session. But I forgot you can open a session with plugins disabled....thanx for that I am gonna try that.
Installing Keystudio after Vocal Studio petert MIDI 4 12-26-2010 11:29 PM
Error installing 7.4 ! jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-16-2007 12:58 PM
Music Studio installing ICON tekmstr ICON & C|24 11 12-04-2004 10:11 AM
Do you have any specs for installing a dedicated power curcuit(s) for the studio? michaux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-26-2003 10:36 AM
DAE error -9095 with PEAK 2.62 earthling2663 Pro Tools TDM Systems (Mac) 0 09-27-2001 04:02 PM
