Old 05-06-2022, 06:58 PM
stevedresser83 stevedresser83 is offline
Default 10+ sec delay loading plugins with 2022.4 update
It's not every plugin or every time, haven't found an obvious pattern to it, but some sessions seems to just start doing this randomly. Can be anywhere from maybe 5 second delay to maybe 15-20 max. Never had this problem before. I've uninstalled, deleted protools folder from appdata, reinstalled. Same issue.
Prior to this update I hadn't updated protools in about a year (i skipped at least one update if not 2 / I think i had the version where darkmode was first added). Not sure what version # I was in but I had no issue like this at all. No other obvious changed to the system. I did install some avid plugins I never had installed before and updated the HD driver to the latest.
Anyone else experiencing similar? Any ideas to try before I uninstall and downgrade to the older version that seemed stable for me?
Old 05-06-2022, 07:53 PM
Default Re: 10+ sec delay loading plugins with 2022.4 update
Try trashing preferences. The first restart after that *will* be slow as all plugins are rescanned, but what are subsequent ones like?
Try disabling or uninstalling any antivirus crapware, including Windows defender. A leading cause of startup performance issues on Windows.
I'm out of date with code signing/authentication on Windows but try disconnecting your computer entirely from any network and trying again just in case it is related to code signing/authentication.
Old 05-06-2022, 09:57 PM
issue persists.
anyone know what ver of protools was the darkmode update and also the corresponding HD driver?
Old 05-06-2022, 10:58 PM
You tried all three things suggested? You don't have antivirus installed? etc.
15 seconds per plugin when it's slow or 15 seconds to start loading all plugins?
Old 05-06-2022, 11:01 PM
yes tried everything.
15 seconds to add a plugin. Not loading on protools start up but in the session while working. Just spins and eventually loads. Really messes with flow.
Old 05-06-2022, 11:08 PM
Doh Sorry I totally was confused and I thought it was initial startup loading of plugins.
Old 05-06-2022, 11:12 PM
no worries. Just to be extra clear, for example, i open up soothe2 and it stalls out for about 25 seconds. I open up decapitator and it stalls out about 15 seconds. Fab-q, loads instantly. Go to audiosuite to apply a reverse to something, 10 sec. Prior to the update my computer ran great. No delays at all like this. Everything felt snappy and pretty instant, even in massive mix sessions.
Old 05-07-2022, 06:31 AM
junkgear's Avatar
junkgear junkgear is offline
issue persists.
Pretty sure dark mode was introduced in version 2020.11.
Just out of curiosity, do you notice slow loading of plugins that use a certain authorization type. Like all my iLok plugins load slow, but non iLok ones load quickly or vice versa?
Will
System Details
Old 05-07-2022, 06:37 AM
its2loud its2loud is offline
How did you install the update? Did you uninstall the old version first or install 2022.4 over it? Can you provide any system info?
Old 05-07-2022, 08:42 AM
All plugins are ilok. I first installed over previous version, then as an attempted solution i uninstalled fully, including deleting appdata folder. I could try uninstalling again and literally deleting every folder. Copying plugin folder to desktop temporarily.
cpu i9-9940x
w10 pro with latest updates avaiable
Burl b80 digilink w avid HD pci-e card
64gb memory
SiSoftware Sandra
ID
Host Name : DESKTOP-NRPCAOV
Workgroup : WORKGROUP
Computer
Model : GigaByte X299 UD4 Pro Default string
Serial Number : Default*******
Chassis : Default string Desktop
Mainboard : GigaByte X299 UD4 Pro-CF
BIOS : AMI (OEM) F6 10/02/2019
Intel Management Engine (ME) : 11.11.65.1590
Total Memory : 63.75GB DIMM DDR4
Processors
Processor : Intel(R) Core(TM) i9-9940X CPU @ 3.30GHz (14C 28T 4.12GHz/4.5GHz, 2.4GHz IMC, 14x 1MB L2, 19.25MB L3)
Chipset
Memory Controller : Gigabyte Xeon (Skylake-E) DMI3 100MHz
Memory Controller : Intel Sky Lake-E Integrated Memory Controller 100MHz, 2x 16GB DIMM DDR4 2.4GHz 128-bit
Memory Module(s)
Memory Module : Kingston/Hynix (Hyundai) KHX2666C1316GX 16GB DDR4 2Rx8 PC4-21300U DDR4-2666 (17-17-17-40 4-57-19-6)
Video System
Monitor/Panel : VIZ M321i-A2
(1920x1080, 41.9")
Video Adapter : NVIDIA GeForce GTX 1650 (896S 14C SM6.5 1.49GHz/1.74GHz, 1MB L2, 3.9GB 8GHz 128-bit, PCIe 3.0 x16)
Graphics Processor
CUDA : NVIDIA GeForce GTX 1650 (896S 14C SM7.5 1.49GHz/1.74GHz, 1MB L2, 4GB 8GHz 128-bit)
OpenCL : NVIDIA GeForce GTX 1650 (896S 14C SM1.2 1.49GHz/1.74GHz, 1MB L2, 4GB 8GHz 128-bit)
D3D 11 : NVIDIA GeForce GTX 1650 (896S 14C SM12.1 1.49GHz/1.74GHz, 1MB L2, 3.9GB 8GHz 128-bit)
OpenGL : GeForce GTX 1650/PCIe/SSE2 (4GB)
Storage Devices
Disk : Samsung SSD 970 EVO 1TB (1TB, PCIe3x4/NVMe, SED)
Disk : Sabrent Rocket Q (2TB, PCIe3x4/NVMe)
Disk : Seagate ST4000LM024-2AN17V (4TB, USB3/SATA600, 2.5", 5526rpm)
Logical Storage Devices
Hard Disk (C:) : 931GB (NTFS, 4kB) @ Samsung SSD 970 EVO 1TB (1TB, PCIe3x4/NVMe, SED)
Hard Disk : 505MB (NTFS, 4kB) @ Samsung SSD 970 EVO 1TB (1TB, PCIe3x4/NVMe, SED)
Sabrent 1 (D:) : 2TB (NTFS, 4kB) @ Sabrent Rocket Q (2TB, PCIe3x4/NVMe)
Sabrent 2 (E:) : 2TB (NTFS, 4kB) @ Sabrent Rocket Q (2TB, PCIe3x4/NVMe)
Seagate Expansion Drive (F:) : 4TB (NTFS, 4kB) @ Seagate ST4000LM024-2AN17V (4TB, USB3/SATA600, 2.5", 5526rpm)
Hard Disk : 96MB (FAT32, 1kB) @ Samsung SSD 970 EVO 1TB (1TB, PCIe3x4/NVMe, SED)
Peripherals
LPC Hub Controller : Gigabyte X299 (Union Point) LPC/eSPI Controller
LPC Hub Controller : ITE IT8686E
Audio Device : Gigabyte ICH200 (Union Point) HD Audio
Audio Codec : Realtek Semi 1220
Audio Device : AVID Tech HD Native
Disk Controller : Gigabyte ICH200 (Union Point) PMC
Disk Controller : Samsung NVMe SSD Controller SM981/PM981
Disk Controller : Phison Electronics Corporation E12 NVMe Controller
USB Controller : Gigabyte ICH200 (Union Point) USB 3.0 xHCI Controller
USB Controller : Gigabyte ASM2142 USB 3.1 Host Controller
SMBus/i2c Controller : Intel ICH SMBus
SMBus/i2c Controller : Intel MCP7-E(P) XMB Ch 0 SMBus
SMBus/i2c Controller : Intel MCP7-E(P) XMB Ch 1 SMBus
Printers and Faxes
Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour)
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : Epson ESC/P-R V4 Class Driver (360x360, Colour)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Peripherals
Media Player : Seagate Expansion (3.64TB)
Network Services
Network Adapter : Intel(R) Ethernet Connection (2) I219-V (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.19041
Platform Compliance : x64
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 3 : Double-click tip or press Enter while a tip is selected for more information about the tip
2022 update: routing Mac Built-In audio to PT? Eric Lambert Pro Tools 27 05-13-2022 12:41 PM
Does the new 2022.4 update fix the loosing I/O setting bug K Roche Pro Tools | Carbon 7 05-01-2022 02:56 AM
Pro Tools 2022.4 update is a DISASTER! jplumlee Pro Tools 9 04-28-2022 12:58 PM
Pro Tools plug-ins bundle 2022.2 update? MacMax Pro Tools 2 03-30-2022 07:27 AM
Jan 2022 Apple Security Update bricking display again OAG Avid S1, S3, Dock and Control App 2 01-04-2022 09:46 AM
