Noise from Main Out L (hardware problem?)
Howdy folks,
There is a disturbance in the force I have my 11R plugged (in stereo) into a mixer that feeds my speakers. Lately, I've noticed a static sounds being emitted from the Main Out L, with intermitten pops. I've tried plugging into different inputs on my mixer, switching cables around, lifting the ground, not lifting the ground etc., but this static noise persists. When the main volume is on 0 (and also when I mute the main out), there is no difference in the static that's coming out of the speakers. It doesn't register on the I/O meters, cannot be heard over the headphone out, nor does it come out from Output to Amp 1 (regardless of what output to amp is set to). Changing the clock source also has no impact on the sound. Any ideas before I send it in? I'd really prefer not to have to do that, I'd miss her too much |
Re: Noise from Main Out L (hardware problem?)
What happens when you flip the cables (plug the cable on the right into the left jack of 11R and vice versa)? If the noise flips to the other speaker then it sounds like an 11R hardware problem, if not then it sounds like a problem somewhere else in the signal chain.
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
Okay the problem is persistent and confirmed... time to call in the warranty. She will be missed *sniff*
Mbox 2 Inaudible -10dB "noise" on one channel - hardware problem? | andreuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-19-2009 10:00 AM |
noise+hardware buffer size, and cpu usage problem! | kanxan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-16-2005 04:18 PM |
Noise out of the Main Out | hosea88 | ICON & C|24 | 2 | 10-10-2005 02:21 PM |
Hardware Inserts on Main Stereo Out | Brimmy | ICON & C|24 | 1 | 10-04-2003 11:07 AM |
Noise in Main Output | Jamble | ProControl, Control|24, Command|8 | 0 | 04-22-2000 09:03 PM |
