whats the least ram and speed I can get away with running pro tools le. My desktop only has 256mb of RAM. will this be a problem? How does pro tools work with mac. I am thinkning about buying one.
That's a big problem. Minimum requirement for LE 7.4 is 1Gig, and you'll certainly need more if you run much in the way of VI's, Samplers, etc.
Even if you upgrade your RAM, I would suggest looking at this: http://www.digidesign.com/index.cfm?...5&itemid=28565 to make sure the rest of your hardware is compatible. Good luck. . .
JP |
thanks, ive been trying to find that page. I think I over bought with pro tools, probably should have stuck with a simpler program. I just want to record some vocals and guitar tracks. and maybe add some drum effects or a midi synthesizer. I currently have an IBM desktop with windows xp proffesional w/ service pack 2. pentium 4 2.66 ghz, and 256 mb ram. I can upgrade to 1 gig of ram for $70.00 IF I do that, will I be ok? I have pro tools le 7.3 and m-box mini. Thanks for any help!!
one other thing., what is a fire wire and do i need it, or do i have to have it?
What is a firewire? Now I am a bit scared. Firewire is a transfer interface that is used for external drives, video cameras and digital audio interfaces such as those from DIGI, Presonus or MOTU. You need firewire IF you have either a firewire DIGIDESIGN interface(003, 003, Mbox2 PRO), or you want to record to an external hard drive(USB is not supported but firewire is). External hard drives need to use the Oxford chipset or they may not work. Most desktop computers have space inside for expansion by adding a second internal drive(definitely the cheapest route). Since I don't know if your computer is compatible, I recommend adding RAM anyway and 256 is really not even enough to run Windows effectively. Add at least a 512 stick (or 2) and add a second internal drive(7200 rpm is a must but size can be whatever you can afford). When you format the second drive. make sure you format it as BASIC and not DYNAMIC(not supported). Install your protools software and pay strict attention to the directions in the Getting started guide(if you do the old "attach the hardware and let Windows do its thing", most likely your install will not work. I suggest you read the tweaking section twice, perform the tweaks, then read the install instructions twice before you tackle it as that will save you lots of headaches.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
PT8/Plug-ins Minimum Version Requirements | Erik Zobler | Pro Tools TDM Systems (Mac) | 36 | 04-29-2009 05:04 PM |
I don't want a monster or the minimum requirements | jsanders | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-13-2005 01:15 PM |
Minimum System Requirements for 002 | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-10-2005 01:57 PM |
What is the minimum hardware requirements for booting PT 5,0,1 | DallasPA | Pro Tools TDM Systems (Mac) | 2 | 06-01-2003 10:51 AM |
What are the minimum requirements for Pro Tools LE 5.01 to run. | the originalman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-29-2001 09:48 PM |
