Dual Monitors for the mix and edit screens ?
Running dual monitors is great. My plug ins go to one while PT works on the main. I have yet to figure out a way to run the mix window on one monitor and the edit on another at the same time. I hope this is an easy fix but you can't drag your work orver to the other monitor using these two main windows. I can drag plugs all day but not the two main working windows. Any suggestions? thanks
When I die, I want to go like my Grandpa did, quietly in his sleep and not like the screaming passenger on the back of his motorcycle! |
Re: Dual Monitors for the mix and edit screens ?
You have to minimize the main window, then click on the edge and drag it over so it's covering both monitors.. Then you can place your edit and mix windows wherever you like!
Now that's what am talking about!!! Thank you
no problema..
dual monitors separate mix and edit windows? | bonzerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-14-2010 10:24 AM |
How to setup seperate Mix and Edit windows on Dual Monitors | G.roots | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-03-2007 08:11 PM |
Maximize internal edit/mix windows on dual screens | Jesse Jackson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-24-2006 08:27 AM |
Setup Pro Tools with Dual Monitors (Edit View, Mix | rcourell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-16-2005 06:05 AM |
Mix & Edit settings when using dual monitors | DEVIZE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2003 07:32 AM |
