Old 10-16-2006, 12:33 PM
satpat satpat is offline
Default PRO TOOLS 5.0.1 freezes on startup
When I double click on the PRO TOOLS on my desktop it freezes; arrow moves but have to Force quit
comments?
thanks
Pat
Old 10-16-2006, 01:06 PM
KingTor KingTor is offline
Default Re: PRO TOOLS 5.0.1 freezes on startup
First of all, you have to be running OS 9, because PT 5 won't run on OSX, not even in classic mode.
If you are in OS9, then I'd try trashing PT preferences files (I don't remember exactly where these are in OS9, but if memory serves you're looking for Pro Tools Prefs, DAE Prefs and DigiSetup). After you delete these, empty the trash and reboot. If that still doesn't do the trick, you might have to reinstall Pro Tools, and if that still doesn't work, you might have to reinstall the Mac OS.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 10-16-2006, 01:11 PM
Avid's Avatar
Avid Avid is offline
Administrator
Correct, and you have to choose Mac OS 9 as your Startup system. Pro Tools will not work in Classic when booted in OS X. From your previous post, it sounds like you may be trying to run Pro Tools in Classic:
http://duc.digidesign.com/showflat.php?Number=984392
I'm using a power mac G4 400mhz op9.2.2 I"ve recently added op10.4.3&classic 9
everything is on the master 20gb hard drive.
Administrator
Old 10-17-2006, 01:17 PM
was in OPP 9, moved pref files to desktop, reinslalled Pro Tools;
now i've trashed pref files; still freezes ; I'll re-install OPP 9.0.4
recommended procedure ?? what OPP system should I re-inslall from ?
thanks
Pat
Old 10-17-2006, 08:08 PM
M.Brane M.Brane is offline
Could be an extension conflict. Did you follow the guidelines for creating a new extension set for ProTools?
9.0.4 was not the best version of 9. You should update to 9.2.2 on a 400mhz G4.
Pro Tools 10 FireWire freezes system on project(s) startup Bendik Jensen Windows 1 06-01-2013 01:51 PM
Pro Tools LE 8 freezes multiple times on startup blackblueu2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-05-2011 10:35 PM
Pro-Tools 8 Just Freezes on StartUp Limn Pro Tools M-Powered (Win) 1 08-24-2009 03:39 PM
PT 6.4 freezes after startup logandrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-06-2005 10:39 PM
PT freezes on startup rastro2 Pro Tools TDM Systems (Mac) 3 07-26-2002 06:39 AM
