Re: Sound Designer
sux that SD2 wont work with anything but a few older systems. still got mine and my am2 but thats about worthless. I am in the 'integrate sd3 and MLCD into a NEW osx app' and let us say buh bye to Peak.
http://www.crystalclearrecording.com |
Re: Sound Designer
As I have mentioned here many times, I use SDII with an AMIII in several G4's EVERYDAY, running os 9.2.2. I use it to make up my playlists for CD burning. I have tried other solutions, including JAM, Waveburner, etc., but like this combo the best. Did you know that you have have the same audio files open in Pro Tools, SDII, and MLCD all at the same time, and switch between programs and that file will play in whatever program you have in the front?
Re: Sound Designer
Hi Mike
I've contacted Digi UK and was offered an SDII v2.83 upgrade but this is no use to me as I'm NuBus and need Waves plugs - UNLESS the disk will authorize v2.8. I've emailed them on this but I'm getting no response at all and I need to get authorized again. According to your User Guide for v2.8, as a registered user I should have received a backup installer, but I've never had one. Digi UK did at least confirm I'm registered OK, and I did get backup installers for 2 versions of MLCD and 2 versions of ProTools. Can get something moving please? Thanks David |
Re: Sound Designer
I am an old SD II user. Could Peak be used instead I can't think off hand want SDII has that Peak can't do.
Sound Designer 2.8.3 on a G4 | sschultz | Digidesign Hardware & Software | 6 | 07-21-2019 10:27 AM |
Sound Designer II & Sound Designer Universal | Grigory | Digidesign Hardware & Software | 0 | 04-28-2005 03:18 AM |
Sound Designer II | Light3740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-11-2002 08:21 AM |
We need Sound Designer | CEG | Digidesign Hardware & Software | 26 | 02-03-2000 07:46 PM |
Sound Designer II on the 001? | Matt Z | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-17-1999 12:31 AM |
