Old 10-04-2021, 09:50 PM
BasilF BasilF is offline
Default Sample Size in Session Menu
I'm using Pro Tools 2019. On the SETUP menu, when you go down to SESSION, you'll see SYSTEM DELAY and it is measured in samples. Is there a way to change that. I need to bounce something into a session that, for whatever reason, has a different sample size there.
Old 10-04-2021, 09:52 PM
Default Re: Sample Size in Session Menu
Nevermind. Fixed the problem.
Buffers Size, Sample Rate & Sample Latency?? larsongs Pro Tools 10 23 03-31-2021 06:50 AM
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size sample Pro Tools 11 2 02-24-2016 01:04 PM
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! a2zproductions Pro Tools TDM Systems (Mac) 16 05-08-2008 08:30 AM
VST wrapper menu size wibble 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-15-2007 01:40 AM
The 192 I/O won't register external sync, sample rate menu not active in Pro Tools Affinity Music Pro Tools TDM Systems (Mac) 0 05-18-2002 08:26 PM
