Effect sends Pre or Post fader
Just a little discussion on what people are using most of the time and when they prefer to use Pre/Post fader. I used to alway use Post fader which will affect the level going into the delay, reverb etc, but for some reason ive now turned to Pre fader. I'd just like to get everyones views and opinions on this
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Effect sends Pre or Post fader
The only times I use pre-fader sends are when printing tracks to new audio tracks, creating special FX, and setting up cue mixes.
Back in the old console days, pre-fader was frequently used for things like headphone monitoring, while post-fader was used for effects such as reverb.
Using pre-fader allowed the creation of custom headphone mixes (think "more me") that would not be affected by fader level changes. For example, the drummer might want to hear a louder bass guitar than would be used in the "real" mix. Using post-fader for reverbs allows a more "realistic" use of reverb. If you were using room reverb, if the instrument gets softer, so does the level of that instrument in the total room reverb. By using a post-fader send to your reverb, when you pull the fader down the amount of that signal being sent to the reverb is reduced, thereby preserving the balance of the instruments in the reverb. Of course, you can do whatever you want to in order to achieve the desired sound...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
If you are sending all your drums to a parallel compressed sub mix to blend in with the dry drum buss would you use pre or post. Obviously using post would send the same mix as the dry drum bus to the parallel bus or would you want a slightly different mix to be sent to the parallel drum bus
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis Last edited by Raoul23; 05-20-2013 at 01:17 AM. |
Automating Pre/Post Fader Sends | Matthew Harrold | Post - Surround - Video | 8 | 11-27-2017 06:33 PM |
Clipping of post fader sends in 6.4 | burningbusch | Pro Tools TDM Systems (Mac) | 4 | 06-07-2011 08:01 AM |
SENDS: Post/Pre-Fader which is better/most common? | GapeOne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-24-2004 03:04 PM |
Sends, pre-post fader? | Tito Ricci Arballo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-22-2003 06:16 PM |
Pre/Post fader aux sends not automated?!? | DannyVanSpreuwel | Pro Tools TDM Systems (Mac) | 2 | 11-29-2000 10:45 AM |
