Old 06-21-2005, 10:33 AM
Sergeman Sergeman is offline
Default Help with peaking
Hello everyone,
I'm doing a final mix for a new song and I had a question. In my master fader there's constant peaking. What can I do so that there's no dicernible change on the song's levels themselves... can I add a limiter? Or what about the master fader itself? At what volume is it supposed to be? Does it have to be at 0.0? Or can it be lower?
Thanks for any help!
sergeman
I use Pro Tools and so should you.
http://www.facebook.com/sergeamh
Old 06-21-2005, 11:56 AM
carlos santana carlos santana is offline
Default Re: Help with peaking
yes you should be ussing limiting to avoid cliping
and the master fader sounld be at 0 db
my advice is to use this two in this order
waves linear phase eq
waves L3 multimaximizer
good luck!
Old 06-21-2005, 11:59 AM
ggunn ggunn is offline
Never drive it into the red; there is no soft clipping in digital. The "pocket" in a digital signal is cooler than in analog; although a little bit of peaking may be inaudible, it's best to never see red at all.
Gordon in Austin
Mac G4 Digital Audio 466MHz
MacOS 9.2, 1.25GB RAM, 110GB HD
digi 001, PT LE 5.3
midi peaking DAPianist Pro Tools 10 4 11-21-2013 08:01 AM
Constant Peaking Art Disco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2008 06:07 AM
Vocal Peaking paradigm Tips & Tricks 4 03-05-2007 11:21 PM
Vocal Peaking paradigm Tips & Tricks 1 03-05-2007 08:24 PM
Distortion w/out Peaking??? knewbee Pro Tools TDM Systems (Mac) 0 11-17-2000 10:22 AM
