Mbox 2 + Leopard + PT 8 issues solved, thanks DigiTech
My apologies to the Digi support guy on here if I can off as rude, I was merely frustrated that the system I was so excited about using was causing me so many troubles.
The Mbox 2 issue that many of us are having with it causing programs to hang can be solved (i think?) by following these simple steps 1.If you have a 7.4 installer, install that first! -DO NOT install core audio driver, I believe this is the problem -Verify and repair disk permissions *optional* restart your computer 2.Update Mbox2 firmware -verify and if necessary repair disk permissions 3.Update 7.4 with the two csupdates -verify and repair disk permissions 4.Install Pro Tools 8 -verify and repair disk permissions -restart computer 5.Update 8 with one csupdate -verify disk permissions -restart computer But most importantly, if you have an Mbox2 DO NOT install the core audio drivers. The support guy on the DUC will tell you all day that Leopard and Digidesigns Core Audio has some serious problems, but lucky for us we don't need the extra core audio drivers. I haven't had any problem with hanging programs so far. Well, there was once, but it didn't prevent my computer from turning off and that is the biggest problem I've experienced that others have too. |
Re: Mbox 2 + Leopard + PT 8 issues solved, thanks DigiTech
Actually there should be no need to install 7.4 first, as 8.0 is a full installer. You could skip everything right up to step 4 and, on the Custom Install page, just uncheck the Core Audio driver.
Does that apply to MBox2 Micro also?
Does this mean you can ONLY use the interface with PT though? As in no sound from itunes etc? Tbh, I'd rather live with that than kernel panics, but it'd be nice to have an answer before I remove the drivers
Yes, if you uncheck installing the Core Audio driver, you cannot use it for anything other than Pro Tools.
Just remember - don't unplug the unit while the computer is on and make sure that no application is using the hardware and that the Sound control panel is set to Built In before shutting down the computer. Doing those steps should avoid most kernel panics. |
Even if we do not install CoreAudio we have to take those steps?!!
"don't unplug the unit while the computer is on and make sure that no application is using the hardware and that the Sound control panel is set to Built In before shutting down the computer. Doing those steps should avoid most kernel panics." |
Then you must have the Core Audio driver installed. There is no other way for other applications to play out of the your Digidesign hardware except through the Core Audio driver.
So how would I get rid of the drivers if I have them installed ?
I just deleted the coreaudio.plugin in my system and home system-folder (in Audio/Plug-ins/HAL/..) and rebooted. Mbox still working with iTunes etc. I have to reboot my mac about 3 times a day due to hanging applications that use the mbox... for one year now. So annoying, I really regret I bought it. If there's not going to be a fix soon, I will throw the damn thing out of the window.. so better watch your head if you walk around my neighbourhood Let's hope for the best. |
Registration issues - SOLVED | JGlen | Pro Tools 10 | 1 | 08-03-2013 03:38 PM |
Anything solved on these issues? | gives | Pro Tools 10 | 0 | 10-11-2012 07:19 PM |
iLok issues - SOLVED | kthom | Windows | 1 | 02-05-2012 01:13 PM |
This release has solved many of my issues! | euphoria89 | Windows | 0 | 10-23-2011 08:35 AM |
Mbox 2 Mini + Leopard = Issues? any help? | Ryan ONeal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-14-2008 04:25 PM |
