Old 04-10-2022, 02:27 PM
gives's Avatar
gives gives is offline
Default Ozone 9 Advanced Version 9.12 released April 8, 2022
I just saw this & been off for a couple of weeks. Maybe it's already posted, but just wanted to let everyone know since this is a problem that needed fixing for some of us. RELAY and TONAL Balance are also updated, which I assume are fixes for the same thing.
https://www.izotope.com/en/products/...ase-notes.html
Adds native support for Apple silicon-based Macs.
Ozone VST2 plug-ins are only available in DAWs or NLEs opened using Rosetta.
VST2 plug-in hosting in the Ozone app is only available when the app is opened using Rosetta.
AAC option in Codec Preview is only available when the Ozone app or mothership plug-in are opened using Rosetta.
Adds support for macOS Monterey (12.3.x).
Adds support for Windows 11.
Updated the preset system to install read-only factory presets to root directories and write user presets to the user documents directory.
Improved EQ composite curve drawing in Analog Mode.
Updated the Ozone 9 Advanced installer to include the latest versions of Tonal Balance Control 2 (2.6.0) and Relay (1.3.0).
Bug Fixes​
Fixed issue that could cause sessions with multiple instances of Ozone to hang when opening a session or exporting.
Fixed missing resource file error that could occur when attempting to run Master Assistant on machines with multiple user accounts.
Fixed issue with Match EQ cutoffs not processing correctly after reopening a saved session.
Fixed error message or blank plug-in UI that could appear in Logic on Apple silicon-based Macs upon closing and reopening the plug-in after certain interactions.
Fixed Brickwall High-pass & Low-pass filter instability when processing above the Nyquist frequency.
Composer/Sound Designer/Protools 2024.6 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.8, DP 11.3.2, Logic Pro X 11.0.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
HTML code is On
eLicenser Control (eLC) updated to Version 6.9.1.1168 – released April 30th, 2015 unkJE Virtual Instruments 0 04-30-2015 05:46 AM
eLicenser Control (eLC) updated to Version 6.8.5.1165 – released April 7th, 2015 unkJE Virtual Instruments 4 04-25-2015 10:12 AM
eLicenser Control (eLC) updated to Version 6.8.5.1166 – released April 20th, 2015 unkJE Virtual Instruments 0 04-25-2015 01:10 AM
eLicenser update Version 6.7.1.8145 – released April 22, 2014 unkJE Virtual Instruments 0 04-25-2014 10:27 PM
