Old 10-31-2012, 08:57 PM
johnbarnesiii johnbarnesiii is offline
Default Tracking electronic drums: Separate tracks for each drum??
Hello,
I'm using pt10 le on a Mac. I'm using sampletank for drum sounds. Right now the electronic drums record into one stereo instrument track.
Is there a way to put each drum onto a separate track? Or at least one for kick, one for snare and two for the rest?
If so, how??
Old 11-01-2012, 01:20 AM
zedhed's Avatar
zedhed zedhed is online now
Default Re: Tracking electronic drums: Separate tracks for each drum??
From the Sampletank Manual;
Activate the number of supported outputs according to the sequencer platform. A slider allows you to select the number of stereo outputs to be used by the module. This number may vary among the platforms. Once the slider is set to a value you’ll be able to set the desired out- put pair to the sequencer Mixing desk from the mix area, but only after closing and reopening SampleTank® 2. This is because SampleTank® 2 ‘declares’ how many outputs it will put on the mixer at the startup.
I haven't used Sampletank, but there should be an output selector on each stereo channel.
You'll need to create the required amount of Audio Tracks in Pro Tools then on the input selector of each track, choose 'plugins' and assign appropriate (corresponding with the outputs selected in Sampletank) channels to each track.
I'm assuming you're using Sampletank in Rewire mode.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Adam A8H Monitors
Separate clip/region with a group of drum tracks has a 2-3 second latency. broken81 Pro Tools 10 4 03-17-2014 05:55 PM
Separate interface for multi-tracking underbiteman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-13-2004 12:17 PM
4 or 8 tracks for drums? drum mic theory John Shryock Tips & Tricks 31 02-11-2004 07:59 PM
002 first song - Revised Drums for my first drum tracking session IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-23-2003 12:10 AM
Making Separate Drum Tracks w/Drum Machine mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-02-2002 06:39 PM
