We are encountering the posted error when using our FW HD with PT8. Before launch, both the Project Mix and FW-HD are connected/mounted and ready to work.
Error Description Application popup: Windows - Delayed Write Failed : Windows was unable to save all the data for the file [name_of_the_file_you_want_to_save]. More details about error http://infotechsolutions.wordpress.c..._want_to_save/ Items to note 1. Both the M Audio Project Mix and FW-HD are connected to the 3-port PCI/FW card. Port 1 is the Project Mix and Port 2 is the HD. Could that be the cause? If so, see #2. 2. The HD and Project Mix are both connected with no issue to report when using other applications. Example: Working with Kontakt 3. Kontakt 3 is sounding from the Project mix while the samples are streaming form the FW-HD. (No Kontakt 3 is not in our Digi plugs list.) 3. Could this be something as simple as a bad cable? If so, why does #2 work well? 4. The above error is consistent but random. It can pop up at any given moment. Specs of the FW-HD http://reviews.cnet.com/hard-drives/...tag=mncol;psum PCI 3 Port FW card I cannot seem to locate the manufactures name of said PCI card. Perhaps my Sandra report will help? Thank you in advance for any suggestion, |
change of sample rate on delta 1010lt causes delayed write error | woodpigeonblue | Storage Subsystems | 0 | 01-08-2010 04:29 AM |
delayed write failure | woodpigeonblue | Pro Tools M-Powered (Win) | 0 | 10-28-2009 02:15 PM |
Delayed write failed | gitar10 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-20-2008 01:07 PM |
"Windows - Delayed Write Failed" | mkalei | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-28-2006 01:16 PM |
OT Delayed Write Failure | TULL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 07-06-2004 06:27 AM |
