Old 02-12-2009, 02:25 AM
ireah ireah is offline
Default invalid asio driver on Cubase SX3.
Hello,
First, excuse my english, i will try my best to explain.
I saw that previous users got the same problem, but i couldn´t fin any solution here in the forum. In addition, i have been searching on the Digidesign answerbase, but i can´t find any solution for this.
I have got an Mbox 2 installed on a PC running Cubase sx3. When i open SX3 i get this message:
"ASIO MME Driver:
An active audio port could not be found.
Errorcode: FE1-E-0600"
In the VST Device Bay setup it has the Digidesign ASIO driver selected, but it said INVALID ASIO DRIVER!
I tried reinstalling everything, Protools LE 7.4, asio drivers, Cubase SX3... but it is still the same. I have also diabled the Windows system sounds, and tried reinstalling "Digidesign Audio drivers v7.0"
I have an ASUS desktop computer with AMD 64 Athlon X2, RAM: 2 Gigabyte and 2,21 Ghz processor. OS: Windows XP Professional SP2.
On the "Control Panel", when i open "Sound devices" i cannot see a sound device installed. i cannot listen to music on internet as well.
On the Digidesign Website, it clearly says that this drivers have been tested with Mbox 2 and Cubase SX3. (http://archive.digidesign.com/download/audiodrivers/xp/)
So my question is, what am i doing wrong?
I would appreciate some help with this. Thanks,
Ignacio
Old 02-12-2009, 07:44 AM
TOM@METRO's Avatar
Default Re: invalid asio driver on Cubase SX3.
Are you able to run Pro Tools at all?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 11
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-12-2009, 03:30 PM
yes protools is running ok.
Is with Cubase SX3 that i get this message. Any ideas? pleeeeease
Thanks very much
Ignacio
Old 02-13-2009, 05:23 AM
C´mon guys i am sure somebody out there can give me a piece of advice...
Old 02-13-2009, 09:32 AM
JMS40 JMS40 is offline
Does this mean that you installed the extra downloadable drivers over top of 7.4? If so that's a problem.
The correct matching ASIO and Wave drivers are included in each Pro Tools install package.
The drivers available for download are a Stand-Alone version intended for use only if you don't intend to install PT.
If this is the case, I'd try a complete uninstall using the PT Uninstall Utility, then a fresh install of only the 7.4 package.
Pro Tools Uninstaller Utility - "PTNUKE"
Old 02-14-2009, 05:13 AM
Thanks for that JMS40, i will try it right now...
Cubase SX3 +Mbox / ASIO Driver skeeter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-07-2009 02:10 AM
Digi 001 Asio Driver w/ Cubase SL 2.0 Illmatic Tips & Tricks 0 03-17-2004 04:54 PM
Which ASIO driver w Cubase SX and Digi 001 Jotown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-20-2004 04:16 PM
ASIO Driver beta2 and instruments in Cubase SX Q-ic General Discussion 2 04-30-2003 11:55 AM
Cubase SX and Asio driver under PT 5.3.1 mucky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-29-2003 08:24 AM
