Old 09-18-2008, 12:15 AM
peter99 peter99 is offline
Default vst2rtas not working anymore...
on 7.4cs7? plugins dont appear in protools wrapped menu...
I have vst2rtas 2.1
Old 09-18-2008, 02:07 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: vst2rtas not working anymore...
I have vst2rtas 2.1
Working fine with me and cs7
Have you tried re-wrapping the plugs!
Make sure the VST's are still in the correct folder etc.
Producer, Engineer,
www.ukmastering.com
Old 09-18-2008, 03:31 AM
I installed schaak audio transient shaper and after that run vst2rtas...
and then opened protools and it didnt work
then I tried to install and convert other vst plugins and they all dont appear in protools
BUT: they all work in logic as AU
Old 09-18-2008, 10:05 AM
crizdee's Avatar
Hi, Open up the wrapper and manually select "yes" in the wrapped column. it should turn green if the vst is installed and working correctly.
Can you see the vst plugs in the wrapper browser?
Vst's have to be installed and working correctly for the wrapper to be able to wrap them into RTAS.
Producer, Engineer,
www.ukmastering.com
Old 09-18-2008, 04:03 PM
wow! worked... manually put into yes
chris you saved my ass a couple of times already - thx a lot
ASIO not working anymore tobiasl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-24-2010 09:28 PM
Mbox, PT8, not working anymore on MAC popsnot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-19-2009 03:16 PM
ctrl,cmd and k is not working anymore? lowq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-29-2009 10:54 AM
Stereo Bus Not Working Anymore about2flip Pro Tools M-Powered (Win) 1 12-17-2008 08:38 AM
OMF from avid 11.0 to LE, not working anymore, help kalil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-17-2003 01:21 PM
