Old 09-30-2007, 06:30 PM
Johnny O Johnny O is offline
Default Monitor Bus problem when routed through stage rack?
We are having some difficulty making the monitor bus send level out of a stagerack output, into an wireless IEM transmitter. The Monitor bus itself is working, and also working fine through the actual monitor outputs on the FOH rack, however when we patch the monitor bus in the patchbay out of a stage rack analog output, we get nothing. I have used this function before, and am stumped as to what we could be doing differently. Any Ideas??
My monitor engineer is also curious as to why he cannot invert the polarity on an input, then make a stereo pair with that input and another, without the polarity being reversed back to normal.
Thanks for your help!
Old 10-01-2007, 05:51 AM
eytan eytan is offline
Default Re: Monitor Bus problem when routed through stage rack?
I have another question regarding stereo channels. Is there some way to mute one of the two inputs and to pan the other remaing input to the center? I wanted to do this when one of the inputs (of a stereo channel) was noisy and I wanted to mute it.
Old 10-01-2007, 08:49 AM
musicman476 musicman476 is offline
Perhaps Sheldon has a better answer, but if you have two open mono input channels, that is probably the best way to accomplish what you're wanting.
Old 10-01-2007, 09:52 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Hi Johnny,
Any chance the monitoring level control (near the top of the console) is turned down? This control sets the level for all monitor outputs, including the dedicated FOH Rack outputs and any Stage rack outputs that are soft-patched to the Monitor bus.
When making a stereo pair the right channel adopts the left channel's parameters, including polarity. Part of the reason for this is that a stereo channel is represented as a single strip w/ a single set of controls, so there's no way on the control surface or software to indicate to the user that there's a discrepancy between the two channels (e.g, one has polarity flipped).
Sheldon
Old 10-01-2007, 09:55 AM
Hi Eytan,
There's no way to do this on the channel strip itself; however, in an emergency situation like this I'd go straight to the patchbay and assign the remaining good input to both sides of the stereo channel.
Sheldon
Old 10-01-2007, 04:39 PM
The Trim level was not down. However, we think we have found a problem with the stage rack output card we were using. We are going through our console provider to get the problem taken care of. We are however also experiencing some extraneous fluttering type noises in input channels where plug-ins are inserted, even when there is no signal source plugged into the input. Any ideas?
Old 10-01-2007, 04:50 PM
Hi Johnny,
Glad to hear you've tracked it down.
Does the noise go away when the plug-in is bypassed? And which plug-in(s) are causing this effect? Some of the "vintage" plug-in emulations also emulate the low level noise inherent to the original device.
Sheldon
Eleven Rack Monitor problem fustrun Eleven Rack 1 06-10-2011 06:02 PM
Record form Mix Rack & Stage Rack into 1 Pro Tools system kwz VENUE Live Sound Systems 3 01-04-2011 12:10 PM
Monitor stage box split using venue. borez VENUE Live Sound Systems 3 11-10-2010 08:45 AM
Stage rack problem gbranch VENUE Live Sound Systems 1 04-05-2010 02:16 PM
Losing stage link to 2nd stage rack sonicboost VENUE Live Sound Systems 7 11-15-2009 01:43 AM
