Old 05-31-2006, 01:37 PM
skeeter skeeter is offline
Default Cubase SX3 +Mbox / ASIO Driver
I get the error:
ASIO MME Driver:
An active audio port could not be found.
Errorcode: FE1-E-0600
In the VST Device Bay setup it has the Digidesign ASIO driver selected, but it said INVALID ASIO DRIVER!
I updated to the 7.0 drivers, it gives me the same problem.
Any ideas? Thank You!
Windows XP SP2
Old 05-31-2006, 03:26 PM
Dawg Dawg is offline
Default Re: Cubase SX3 +Mbox / ASIO Driver
Works for me.
Old 06-06-2009, 03:14 PM
Coxy001 Coxy001 is offline
I have the same problem except i'm running Vista 32 Bit Home.
When searching for Asio, there's no option for Digidesign Asio. I only have options for Asio Mutlimedia Driver and Asio DirectX Full Duplex Driver. Neither let me use the Mbox.
The multimedia driver shows the Mbox as being available to use as my o/p, but when I test it, i get exactly the same error msg as Skeeter.
I am not using ProTools, instead opted to d/l the standalone Asio driver.
I have also added Cubase to Digi MME Helper.
Device manager recognises my Mbox and says the drivers are up to date
Anyone know how I can fix this ?
Hope this all makes sense !
P.S. I have the original Mbox, not Mbox 2
Thanks
Old 06-06-2009, 05:20 PM
JMS40 JMS40 is offline
Did you use the 7.4 Standalone Package?
Earlier versions aren't compatible with Vista.
Old 06-07-2009, 02:10 AM
Yeah. Think i've resigned myself to the fact that i'm gunna need a new audio interface. Thanks anyway
Mbox 2 Pro & Cubase SX3 (Asio driver error) Metroid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-08-2009 07:37 AM
invalid asio driver on Cubase SX3. ireah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-14-2009 05:13 AM
Digi 001 Asio Driver w/ Cubase SL 2.0 Illmatic Tips & Tricks 0 03-17-2004 04:54 PM
Which ASIO driver w Cubase SX and Digi 001 Jotown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-20-2004 04:16 PM
Cubase SX and Asio driver under PT 5.3.1 mucky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-29-2003 08:24 AM
