Will it work with Pro Tools?
Hi!
Hope im posting this in the right section. Im about to sell my PC and the buyer wants to install Pro Tools on it (version 9 or 10). But im afraid it wont be compatible with my pc after reading the requirements, so i was hoping someone on here would know if it will work or not. The buyer already have Avid mbox mini and the hardware in my pc is: Motherboard: ASUS M5A97 R2.0, Socket-AM3+ GFX Card: Sapphire Radeon R9 280X 3GB GDDR5 CPU: AMD FX-8350 Black Edition RAM: Crucial DDR3 BallistiX Sport 1600MHz 8GB OS: Windows 7 Pro Hope someone can help me out with this :) |
Re: Will it work with Pro Tools?
Like this: http://avid.force.com/pkb/articles/e...551?popup=true the pc is built in a shop and is not a HP or Dell. It also says i need a Nvidia card? I dont... |
Only way to know for sure is to load PT on it and see. You didn't say anything about the Hard Drive. It needs to be either a SSD or a conventional 7200 RPM hard drive of at least 1tb. You can get away with as little as 350Gb but having more is a lot better, you don't run out of space too quickly. Even better, if you don't have the large Hard Drive as Drive C:, you can add a slave Hard Drive and save everything you record to that and not use up much space on C:. As far as having to have NVIDIA, my PC uses the built in video processor. One of my PC's has NVIDIA, the other doesn't, and I can not see any difference.
Hope this helps. |
I'm not aware of any 1TB requirement. I have used smaller drives as dedicated session drives before, and encountered no issue. I currently use a 750GB hard drive as a session drive in my laptop, and another 750 GB hard drive as one of my session drives in my desktop. I also make occasional use of a 120GB external SSD as a session drive, and have not encountered any issue with it.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
I think my original Sweetwater build from 2006 came with a 200GB audio drive, which was considered pretty large at the time. I never did come close to filling it up. I record mostly at 44.1, 24 bit. For a pro studio operating 12+ hours per day, a larger drive(s) would be needed, but not the average home studio. I currently have a 2TB audio drive, because the price has come down so much, but it is way larger than I need.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Drive capacity is meaningless as long as you have space for A-what you need to install on the system drive, and B-space for recording your projects. Some use a system drive as small as 64GB, but I am partial to a 256 or 500GB Samsung 850 PRO(or EVO for slightly less $). As for a recording drive, again, its up to you, but I would lead toward a WD Caviar BLACK 1TB as the smallest I would use in a desktop machine(personally, I run 2 recording drives of 1TB each, a samples drive of 2TB and a second samples drive of 750GB(just for NI Kontact). Notice that I mention sample drives as separate because 3 drives(system, recording, samples) is the ideal for best performance. If you are sticking with 2 drives, put your sample libraries on the system drive.
One big detail that nobody seems sure about is that motherboard's chipset, which is often the "make of break" detail Beyond that, while AMD may be the king of "budget", intel i7 is the current king of "performance" when it comes to Pro Tools
1) for both PT9 and PT10 Windows 7 Pro will work like you can recheck via the links from DigiTechSupt (for PT 9.0-9.0.1 you better use W7 without the Service Pack, for PT9.0.2+ as well as for PT10 you should use W7+Service Pack 1) 2) the machine comes with 8GB Ram (4GB officially recommended) Another 2 important parts will be (like mentioned by all others already) 3) a fast enough OS drive with a decent amount of storage space (doesn´t have to be 1TB indeed but should not be smaller than 256GB finally) 4) a 2nd separate fast enough, Pro Tools-ready session/audio drive. Both drives must not be 5400rpm HDDs as those are too slow for the use with Pro Tools. Both drives need to be 7200rpm HDDs at the minimum, SSDs preferred. If you got those 4 things covered finally the best bet simply will be to try it out and install Pro Tools on this system. If it isn´t qualified officially doesn´t mean it won´t work. It just means that the qualified and recommended stuff will work for sure (or most of the time at least) and people will have a better Pro Tools life just going with the requirements. However in many cases other stuff will work as well as long the user mind to use A) the fitting OS B) enough memory C) fast enough drives for the OS drive and the 2nd (important) Pro Tools session/audio drive ... must not record to/playback from the OS drive only with Pro Tools except one is using a modern, really high quality 512GB-1TB SSD ... D) a fitting audio interface with the fitting version of the driver E) to do all the optimization stuff before installing Pro Tools. http://avid.force.com/pkb/articles/e...oting/en349411 Yeah, so also make sure to use a compatible and working audio interface with it and be careful to select the fitting driver! Then there is a good chance as those are the most important requirements to get Pro Tools to work finally. The best of success to you! |
Thank you so much for your help guys, and especially to VRW!
The pc comes with Crucial MX100 SSD 256GB (7200rpm). Im guessing all that is left is to install PT and see if it works then. |
Keep the faith that it will work.
Pro Tools 11 doesn't work,Sesions open then pro tools stop responding | tronic21 | Pro Tools 11 | 6 | 07-31-2015 02:27 AM |
Bought Pro Tools 11(academic), given pro tools 12 licence, doesn't work! | TimCollins1311 | Pro Tools 11 | 2 | 03-17-2015 09:52 PM |
Need help getting pro tools work! | Tobias Winther | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-14-2009 11:00 AM |
does pro tools le 6.8.1 work on mac os 10.3.9? | wesley13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-21-2007 04:54 AM |
How does pro tools HD Work? | sethbrand | Pro Tools TDM Systems (Mac) | 1 | 03-21-2007 03:33 AM |
