Old 09-10-2021, 04:00 AM
digiplex digiplex is offline
Default Tempo map to strict tempo
I have a recording that wasn’t tracked to a click. If I tempo map it how do I then have it converted to a flat strict tempo?
Old 09-10-2021, 08:26 AM
Default Re: Tempo map to strict tempo
Not sure you can do it inside PT. Some versions of Melodyne can do this in standalone mode(you open the audio file in Melodyne>let it analyze the selection and then you can force it to a constant tempo). This process is done outside of your DAW(and not all versions of Melodyne include this option. Its not exactly easy to figure out, so watch some tutorials on how to do that if you decide to download the demo. I have used it myself(I own the "Studio" version of Melodyne) and it does work, but the audio file will determine how well, according to the song. For example, if the song has a stop anywhere, that can confuse Melodyne into changing the length of the stop(solution is to select audio on each side of the stop and set the tempo, then go back to the stop and adjust manually to fit).
Old 09-10-2021, 08:45 AM
Trying to conform a rubato performance to a non-varying click isn't trivial. Best bet within Pro Tools would be Elastic Audio. Depending on number of tracks, complexity of audio/performance, etc this may be easy, moderately time consuming, or a huge undertaking. If it's a fairly simple performance/track you can let EA analyze in polyphonic mode, set the tempo you want, move the first and last warp markers to ballpark it and then go through and add/quantize warp markers as needed to get a consistent performance. Once it's where you want it, set the EA algo to X-Form and render it so the fidelity is better. Results will vary depending on exactly what it is you're working with.
Like @albee1952 says, Melodyne *may* also be helpful, again depending on specifics.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 09-10-2021, 09:22 AM
I am hoping the OP is only working with a single audio file as doing a multi-track would be........ As Rich said, EA can work(if its a multi-track, enable the ALL group first). If I were to use EA for this, I would probably cut the song up into manageable chunks. Use Tab to Transient to locate the downbeat of sections like verses and choruses and cut at those points. Once you have each section evened out, you can move them back together
Old 09-10-2021, 01:45 PM
DetroitT's Avatar
DetroitT DetroitT is online now
This may give you some ideas.
https://youtu.be/uUjuN4lWJ_U
Old 09-10-2021, 03:18 PM
midnightrambler midnightrambler is offline
“Not sure you can do this in PT” ��FFS
It’s not that hard, you just need patience. In essence : make a *decent* tempo map (that’s the bit that requires patience), switch everything into elastic / “tick-based”, reduce the analysis markers to 0%, then turn the conductor off and choose your tempo. Et viola et voici.
Old 09-10-2021, 03:59 PM
cwsand's Avatar
cwsand cwsand is offline
It can be done as described with Elastic Audio if you're ok with some loss of quality. I would use Beat Detective to slice up the drums though, use "tick-based" and then when you remove the tempo map and replace it with one tempo, the drums will move accordingly. Then use Fill & Crossfade. EA kills drums IMHO.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-10-2021, 08:28 PM
Ben Jenssen's Avatar
I second this.
How do I match tempo of rex2 loop to master tempo siuberto Socarras 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-27-2010 11:23 AM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Tap tempo and involuntary time shifting with tempo changing Skiroy Pro Tools M-Powered (Win) 3 08-26-2010 10:00 AM
Pro tools tempo wont match keyboard tempo via midi Killah Kane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-18-2010 01:55 PM
Ramping a Tempo Change (interpolation or discrete tempo points) edgarbc1 Tips & Tricks 3 02-18-2009 12:55 PM
