Old 08-16-2021, 11:04 AM
clampire clampire is offline
Default Strike 2 Latch not working in PT12
When I draw with the pencil tool in my Instrument track with "notes" selected, I see the pattern. However, only the first crash is heard. Latch and Style are highlighted. But still, the pattern does not play in its entirety.
If I click on any key in the Verse, Intro, Fill, Bridge, Chorus, etc. on the keyboard in the Strike window, the patterns continue to play out correctly.
Sorry if I sound naive. Just recently purchased this new iMac and Strike 2. It's been about two years since I had the original Strike working on my older iMac.
Do I need to set up patches? Any advise would be greatly appreciated.
Old 08-16-2021, 11:47 AM
Top Jimmy's Avatar
Default Re: Strike 2 Latch not working in PT12
If you’re triggering a pre-programmed loop or pattern, you have to draw the note out to the length that you want it to play.
Latch is an automation writing mode. It has nothing to do with MIDI.
James Cadwallader
Old 08-16-2021, 11:49 AM
Top Jimmy's Avatar
I suppose you can use sustain to do it too.
James Cadwallader
Old 08-16-2021, 12:39 PM
I stretched the note to 4 bars (16 beats) and still no good!
Old 08-16-2021, 12:42 PM
Since it works in Strike when I click a pattern and it performs repeatedly, I suspect the problem is in Pro Tools.
Old 08-16-2021, 12:45 PM
Top Jimmy's Avatar
Are you sure you’re drawing on the right note? IIRC, individual hits are found in the upper octaves while loops and patterns are found in the lower octaves.
James Cadwallader
Old 08-16-2021, 12:58 PM
You may be right. It's working in one of my three sessions I tried now. Once I find out the difference in them, I will post what I came up with.
Thank you both!
Allow Latch Prime to softkey not working kava Avid S4/S6 1 02-17-2020 09:36 AM
Auto function (write, touch, latch etc) not working mr xy Avid S1, S3, Dock and Control App 7 05-19-2016 01:01 AM
Strike, latch not working pianosound Virtual Instruments 1 02-09-2016 11:44 PM
Latch Mode not working/sporadic AudioMaster Pro Tools TDM Systems (Mac) 8 05-26-2009 05:50 PM
Autowrite/touch/latch not working on mix window ilianarose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-08-2007 06:17 PM
