Routing audio from CoreAudio apps to Pro Tools
I'm currently routing audio from the digital out of my Mac to the digital (adat) input of my Omni-interface.
Is there any other way of getting audio from the Mac via for example Soundflower into the PT HDX-engine? I got a bit confused reading about Soundflower, RevoicePro and PT HD hardware: http://www.synchroarts.com/AppSuppor...onitoring.html From the PT manual: "The Pro Tools Aggregate I/O Device is intended for use only with the built-in audio on your Mac computer."
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60 macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4 |
Re: Routing audio from CoreAudio apps to Pro Tools
The thing they don't tell you is that the digital input on the MAC is NOT supported.... unless something has recently changed. Not sure on Sundflower....
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
It's definitely possible with sound flower. But I think you would need to use the pro tools aggregate instead of your omni.
I don't think HD systems work with aggregate audio.
Thank you, that seems to be the case.
Hopefully in a future version...
Buy a Hosa Spdif Optical - AES convertor ($80.00) and connect your Mac optical i/o to you Avid AES convertor ports.
I did exactly this and I could not get it to work. I suspected immediately that the HOSA CDL-313 unit I purchased is defective. I assume by your suggestion Touchwood that you have successful used this in a similar application....right?
Best Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
routing other audio apps through mbox? | sterndrup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-05-2008 10:13 AM |
How many 002R outputs in CoreAudio Apps? | sdevino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-05-2006 06:32 PM |
Digi CoreAudio setup probs. Can't add/remove apps. | soundboy69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-15-2004 09:28 AM |
Digi CoreAudio vs. other open apps | jes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-30-2003 10:09 AM |
Audio of other apps thru Pro tools 5.1? | SteveGarman | Pro Tools TDM Systems (Mac) | 5 | 05-05-2001 07:17 AM |
