Old 11-08-2010, 06:45 PM
tonyK tonyK is offline
Default xpand2 drum set samples
Hi everyone. I have a stock version of pro tools 8 le, which comes with xpand2. I'm wondering if there is a drum set i can use there so that i can map my keyboard keys to individual drums. I don't want to use their drum loops and I don't want to record each drum instrument separately. I want to C2 to be a kick drum, E2 to be a snare, F#2 to be a hi-hat, etc. Thanks!
Old 11-08-2010, 07:14 PM
Default Re: xpand2 drum set samples
Xpand!2>Part>Category>024 Drums
Aaron Mulqueen - 001 HD Native
Old 11-08-2010, 08:52 PM
thanks filosofem, however when i choose one of those options under 024, i get an entire keyboard of hi hat sounds, snare sounds, kick sounds, etc, but I need the keys C2-C3, for instance, to give me an entire range of drum set sounds so I can "play" a drum set with those keys. Is that available and I am just missing it? Thanks.
Old 11-08-2010, 09:42 PM
Use 'Menu'.
Old 08-18-2021, 02:54 PM
mslinn's Avatar
mslinn mslinn is offline
Originally Posted by filosofem View Post
Use 'Menu'.
I have the same problem, but the terse message "Use menu" does not help me. How to do this?
Old 08-18-2021, 07:08 PM
unkJE's Avatar
unkJE unkJE is offline
Originally Posted by mslinn View Post
... How to do this?
... by setting up 4 Instrument Tracks ...
Excellent Video:
Pro Tools First Tutorial (Part 4) – Xpand!2 Virtual Instruments
https://youtu.be/eCmk1vk9aKw
Control Automation with Encoder – set to 4 Encoders to CC111, CC112, CC113, CC114.
Right-click on any LEVEL Fader – select Learn MIDI CC.
… how to do even more with one instance of Xpand2 by using automation
https://vimeo.com/channels/protoolse...usive/37422751
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 08-18-2021, 10:24 PM
Top Jimmy's Avatar
Load a full drum kit via the plugin preset menu at the top of the plugin window rather than using the selector menus in the 4 individual sections. The plugin preset uses all 4 sections to create a whole drum kit set of sounds available for playing via a single MIDI channel. All the sounds you wish to play may not be within a single octave, but they aren’t hard to find.
James Cadwallader
Old 08-19-2021, 07:09 AM
mslinn's Avatar
Top Jimmy, thanks for helping out.
I have a Roland HandSonic HPD-15 drum, not a keyboard. It has 14 pads, which emit MIDI notes from C3 to D4. Somehow I need to map those pads to Xpand2. I would prefer to leave the MIDI notes emitted by the HPD-15 as they are, and instead map them to 4 sounds of the XPand2 patch I am using at the time.
As a Windows user, I was able to install VMPK, a virtual keyboard, and loopMidi, a virtual MIDI cable, to explore all of the available sounds on XPand2. That worked quite well. When displayed on a Dell P2418HT touch-sensitive monitor, I was able to play chords by 'playing' the virtual keyboard. However, as a drummer, I want to play a drum, not a keyboard.
Maybe Bome MIDI Translator Pro can do the translation, but it seems complicated to set up. Is there an easier way to map the HPD-15 drum pads to specific XPand2 sounds?
Old 08-19-2021, 07:24 AM
The better way is to not use Xpand2 and move to a drum-specific VI. I can highly recommend Addictive Drums2, EZDrummer2 and Superior Drums3. They are all very capable(much better than Xpand2) and will allow for more "real drummer" sound due to the multiple samples. While I am not positive that the first 2 options allow midi remapping, I know that SD3 does(I suggest watching some demo videos on all 3 to get a deeper look). Xpand2 is fine for making a drum track for fleshing out a song, but if you want the end result to sound like a drummer(instead of a machine), then Xpand2 is not the right tool for the job
Old 08-20-2021, 05:11 PM
Top Jimmy's Avatar
Not that I know of. Since Xpand doesn’t have a way to move sounds to different notes, the only way to do it is to change the notes sent by the drum pads or use a translator. Personally I would just change the notes on the pads.
James Cadwallader
My electric drum kit won't work with Xpand2 Drums but works fine with Boom? thrice506 MIDI 7 03-26-2014 04:58 AM
XPAND2 Drum Help Soloudsky Virtual Instruments 3 08-01-2013 12:39 AM
Distorted Double Bass samples in Xpand2 tooold Virtual Instruments 15 12-04-2011 04:44 AM
Xpand2 Drum Kit Panning zlr77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-07-2011 06:21 PM
Best Xpand2 drum samples locked in the loops chrisdee Virtual Instruments 4 05-09-2009 01:44 AM
