Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 04-28-2010, 05:34 AM
goat1927 goat1927 is offline
Default 2 Tracks of Same Instrument in Reason
Hi there,
I'm using Reason in ReWire mode and am trying to record two separate tracks of the same instrument. To make things a bit easier, I've created 2 of that one instrument in Reason, and then selected my Reason channels accordingly in PT8.
When I play (while or while not recording, but when record enabled), I get visible output only from the appropriate instrument in Reason, but I get input on the meters and recorded audio on both tracks in PT8, so essentially, it just records both "parts" on both tracks.
I have my master keyboard option deselected, but cannot figure out why this is going on.
Can someone help?
Thanks,
MJ
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Pt le 7.4 & reason 2.5 instrument tracks? nikko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-27-2008 10:57 AM
Configuring Reason instrument tracks jfortiv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-09-2008 03:34 PM
No Instrument Insert on Instrument tracks Bazbo Virtual Instruments 4 03-01-2007 06:00 AM
PTLE7.0 Instrument Tracks with Reason - no output? dwacker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-30-2005 05:25 PM
