Old 02-20-2003, 09:27 AM
Larry Pate Larry Pate is offline
Default Mackie HUI fader vibration
While using the HUI with 001, faders vibrate, rattle, ect. Some times just one, sometimes 2 or 3. I sent the unit in to Mackie to fix. When I got it back it worked fine for a week or so, then the faders started their shake and rattle again. Anyone out there experience this and is there a fix.
Mac mini 1.42, 1G Ram. OS 10.4.11, Digi 002, PT7.4cs1, LaCie d2
Waves Musicians Bundle, GTR, ST2x, Reason 3
Old 02-20-2003, 10:11 AM
doug kaufman doug kaufman is offline
Default Re: Mackie HUI fader vibration
I've had the exact same problem with my HUI.
It seems to happen most when faders are at or near unity, so I try to move the channels around to keep those faders away from the problem channels on the HUI.
dpkaufman.com
Old 02-20-2003, 10:16 AM
kenhawkins kenhawkins is offline
I have a HUI myself and have experienced this. on the mackie boards there was a thread that suggested the elecric feild where the HUI is setting has alot to do with it though mackie has said nothing officially. when i reworked my studio over the weekend i did notice that the #7 fader now jitters. it used to be the #3. what this means exactly i do not know but it might suggest some truth the the electric feild demon :>
for me it is hardware only and does not move the DAW fader. does your faders in Pro Tools move as well?
since mine did not i am not ready to part with it to go in the shop.
ken;
What is Ken Hawkins up to?
Old 02-20-2003, 11:21 AM
Thanks for the feedback. It does not affect the onscreen faders. The promblem seeems to move around. Oneday it could be 1&5, then later 3& 8. I would think Mackie knows what the promblem is, because as I said, after I got it back from the factory it worked fine for a while. I posted this subject on Mackie's support website, but never got a rsponse. It does not seem to affect the performance of PT, just irritating.
Old 02-20-2003, 02:20 PM
Mark Ptak Mark Ptak is offline
Have dealt w/ this problem as well. Where I work, we sent the Mackie back and got a new one which worked for a while, then did the same thing. And the problem also moved around to different faders every few months. We even had our resident Mr. Scott do something to fix it. it worked for a while then...yup...back to the same ol' same ol'. What is this gremlin??!!
I understand what you're saying, but it makes no sense to me...
Old 11-01-2022, 01:17 PM
crisnich crisnich is offline
Hello friends. I know the answer is quite lagged from the thread's original date, but the Mackie HUI device is still in use and the issues recur. I am a musician, but also an electronics technician and a happy owner of one of these controllers (which I bought broken and fixed), and to get straight to the point, I will comment on the faders that jump, oscillate, vibrate: The biggest cause of this problem is, generally, lack of ground on the fader controller board. I suggest removing the plate that is behind the faders/motors, and doing a good cleaning on the screw terminals, a light sandpaper on the grounding contact points may solve the problem. Another important thing is that due to age, the power supply capacitors may need replacement with new ones.
Some DUAL LINE type connectors may also need a good cleaning, contact reactivation or even re-soldering, on the part of the pins.
I hope I have helped a friend who may have problems with their Mackie HUI, and if they need it, I have electrical schematics, service manuals and many tips on how to solve problems in this wonderful console.
A hug to everyone!
Cristiano N.
[email protected]
MC Mix Fader Vibration Roger Stauss Artist Series 0 04-13-2011 03:42 AM
Mackie HUI Fader Replacement TimNielsen Pro Tools TDM Systems (Mac) 12 12-31-2010 08:09 PM
Mackie HUI Fader Calibration Trittschall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-25-2009 12:54 PM
Mackie HUI fader Jitter? micline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2008 04:39 PM
Mackie control fader nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-17-2004 08:02 AM
