Old 11-08-2022, 09:04 AM
EddieJones's Avatar
Default Re: Dock Buttons out of order 2022.9
Originally Posted by Basslice View Post
I am having a similar problem (Windows 10 user). All the assignments are messed up and when I try to change them, they keep reverting back to the wrong assignments. Very frustrating and time-consuming. I spend most of a mixing time session just dealing with this and it is still not right.
Here is where the default ones are stored: C:\Program Files\Euphonix\EuCon\SQRL These are where it pulls the data from when you press default
Some are also supplied by the DAW and are here: C:\Users\<username>\AppData\Roaming\Euphonix\DYN_A PPSETS If theres one in here it will use this over the default ones above, when you press default
Also the user ones are here: C:\Users\<username>\AppData\Roaming\Euphonix\UserS ets\MC2User\MC_USER_SET__Root These are the ones EuControl uses on the surfaces. They are copied over from the default folders when you press default. They are the ones you are currently editing. These are the ones you backup if you have made a lot of changes.
If you are getting weirdness, it's likely the xml file is corrupt. First do an export to save any custom softkeys you have programmed as a backup or copy the who user folder somewhere. Then uninstall EuControl and delete any files in these 3 folders. Reinstall EuControl. Look at the softkeys and see if they are now OK. If you did an export, you could try importing it, but it could be the source of the corruption.
Old 11-09-2022, 07:23 AM
Basslice Basslice is offline
Thanks. I am still working on getting this working and trying to figure out what functions the developers actually designed that can be customized. I am wondering if some buttons were not intended to be modified.
Lenovo Legion 5 Laptop PC, Intel Hexa-Core i7-10750H, Nvidia GTX 1650Ti, 32GB DDR4 RAM, 512GB SSD, Windows 10 Enterprise (20H2), 1TB SSD external work drive, Focusrite Scarlett 18i20, Pro Tools 2022.9, Avid Control w/Apple iPad, Avid Dock Control Surface, Avid S1.
Old 11-09-2022, 08:14 AM
EddieJones's Avatar
If you can change it in the softkey editor than its changeable
Old 11-09-2022, 08:34 AM
Thanks Eddie,
If that is the case then either there is something drastically wrong with the software or my Dock. I make changes and they don't keep and revert back to other settings. Sometimes the softkeys show one thing, but the actual function in the dock are doing something else.
Old 11-09-2022, 08:39 AM
EddieJones's Avatar
Thanks Eddie,
When this happens can you look at what it says next to Application at the top left of the Softkey page. Does this change? Also did you do my suggestion about removing them, just in case the xml has got corrupted?
  #16
Old 11-09-2022, 08:42 AM
Eddie,
I am in my upstairs office, but when I get back into the studio later I will check this out.
Ken
  #17
Old 01-11-2023, 06:26 PM
wickett wickett is offline
Same problem here with dock settings not sticking on mac
Dock and S3 buttons unresponsive (PT / EuCon 2022.4) stargazer Avid S1, S3, Dock and Control App 0 05-01-2022 09:38 AM
Automation buttons on Dock m4tune Avid S1, S3, Dock and Control App 1 01-10-2022 09:08 AM
Dock automation buttons can't be reassigned Eneco Avid S1, S3, Dock and Control App 2 09-20-2021 06:37 AM
New Dock.... flakey right side buttons mattrixx Avid S1, S3, Dock and Control App 26 09-09-2017 01:26 AM
Dock Automation Buttons bug? feakerboo Avid S1, S3, Dock and Control App 0 04-27-2017 08:02 PM
