PTLE VS. Tracktion: PTLE so slow to load plugins!
I just installed a ton of plugins over the weekend and most have both RTAS and VST options.
When I load up PTLE the and it shows "loading plugins" it takes quite a while...maybe 2 minutes to load everything up. Then, when I'm in a session and load up a plugin on an individual track (only 4 tracks are on and only 1 plug in is being loaded) some plugins (Waves, Ozone, etc...) take a while to fully load and operate. However, If I load up Tracktion, the entire process takes about 5 seconds and any plugin I choose (and I have more VST types than I do RTAS) loads up almost immediately and ready to go. Anyone have any suggestions?? Thanks! |
Re: PTLE VS. Tracktion: PTLE so slow to load plugins!
I'd say this is a hardware related issue.
Waves plugins dont take ages to open on tracks for me. They're open instantly. Loading a full mix with numerous instances of Ren Comp Ren EQ Pultecs Focusrite Comps and EQs and it takes less than 10 seconds to build the project. Whats tracktion anyways? The VST wrapped plugins usually take longer to load but RTAS shouldnt Chris Tempest
Digi 002R Athlon 64 3400 K8V SE Deluxe Crucial 1gig DDR PC3200 CAS3 Western Digital 80GB x2 Radeon 9200SE 64 DDR Enermax Noisetaker 370W |
Tracktion is another recording software package...similar to Pro Tools and developed by Mackie. I downloaded the free program last year and really like it!!
I would think that it is hardware related...I think my Ram is too low (512) but it does not seem to happen in Tracktion, so I question why. Perhaps the actual PTLE program itself require alot more out of my PC than running Tracktion.... |
You can end the guesswork on memory usage by looking at Task Manager- it can tell you how much memory is being used by each program, and whether you've used all your physical RAM and started actively using Virtual Memory on the hard disk.
Quad 2.5 G5, 4.5G RAM |
And yes, it does take a while for protools to open if you have a lot of plugins available. Once it is open, sessions load fairly quickly and I don't recall ever waiting for more than a second or two for a plugin to "show up" on the screen.
You need more ram first of all - RAM is king and it is cheap - That's just a general sort of suggestion.
With regards to your plugin loading question I'm gonna just shoot out a few thoughts here - I think that the RTAS plugins are going to load considerably slower than than your basic VST stuff. It usually takes Waves 4.0 a little while to load on my system and I have 1.5 gb of RAM - If I load Ableton Live or Cubase or some other music program that is VST based they all load lickety split. Apples and Oranges in other words. Also - If I get this correctly you installed a bunch of plugins and I'm guessing that some of these were cracked versions. If so you can basically forget about any sort of formal troubleshooting. If you are lucky enough to get stuff without viruses you have to understand that you can never be sure of what you are getting. Sometimes a corrupted file will hose your system and you won't even be aware of it right away - So the first question I guess might be - how many of those plugins do you really need? It is hard to resist I suppose but in the end, having gone down that path myself at one point in time I decided that a lot of that stuff wasn't necessary at all... Of course that's just my opinion. |
Plugins slow to load | wyman | Pro Tools HDX & HD Native Systems (Mac) | 5 | 02-03-2014 01:43 PM |
PTLE will not load | andrewcleaton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-19-2010 04:23 PM |
PTLE 8.0.1 Will Not Load | robob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-08-2009 04:27 AM |
Pro Tools 7.4.2 Slow to Load Plugins | KMFDM | Pro Tools TDM Systems (Mac) | 0 | 01-26-2009 07:06 AM |
Load video in PTLE | Bigpit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-31-2004 07:55 AM |
