Old 08-01-2021, 11:17 PM
Crank Crank is offline
Default Crossfade X-Fade waveform graphic bug
2021.6 incorrectly draws the crossfade in the edit window waveform display. The waveform appearance drops in amplitude while the audio plays as expected.
Attached is a simple demonstration. A continuous sine wave clip is separated then crossfaded. The crossfade waveform draw in the bottom track should appear the same as the corresponding area in the top track.
I remember this same bug from a release around PT9 which was immediately fixed.
It's important to have the graphic accurately represent the faded audio. Seeing the phase result correctly helps to get the crossfade to sound smooth.
I'm not sure if this bug happened in 2021.3. (I upgraded from 2020.11 which was fine).
Old 08-04-2021, 02:40 AM
daeron80 daeron80 is offline
Default Re: Crossfade X-Fade waveform graphic bug
Yep. Been that way a long time. Ages. It's a little unnerving, as it makes you wonder if you chose the right shape, or if PT messed up. But as long as it sounds right, it's not too bothersome to me. Still, you'd think they'd have fixed it by now.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Help- Crossfade and Fade Functions Freeze My Computer jakemmartin Pro Tools 11 0 07-15-2016 09:53 AM
[OSX 10.6.8] PT 9.0.5 - waveform graphic bug Ash06 Pro Tools 9 3 09-10-2011 02:38 PM
fade over crossfade crashes 7.1cs6 jimlongo Pro Tools TDM Systems (Mac) 0 04-13-2006 09:13 PM
Strange waveform graphic steve0916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-13-2003 08:52 PM
