Hooking up new pre to 002
As I'm about to get the UA610 solo today, just curious how to hook it up to the 002, so it bypasses the 002 pre's...Do I put it through one of the inputs on the 002? Will the 002 know to bypass its own inputs? Thank you
Re: Hooking up new pre to 002
Assuming +4dBV balanced XLR output..just build/buy a FXLR > 1/4" TRS cable and go straight into inputs 5>8 on your 002.
good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
What happens if I got XLR into one of the 002 XLR channels?
Then you are preamp-ing twice. You need to plug the UA into one of the line inputs of the 002, which are 1/4" TRS connections. Since the outputs on the UA610 are Balanced XLR, you will need a balanced XLR to 1/4" TRS cable.
But Andrew has already covered that.
Ok, I got this XLR to TRS cable (monster) and plugged it into input 8 and I'm barely getting any levels from the mic...I've tried 3 different mics and I'm still barely getting any levels...
2 possibilities come to mind. 1-bad unit and 2-operator error. Let's try to rule out #2 by doing a little troubleshooting. On the LA610, plug in your mic, set phantom on if required, set the input knob to the Mic-2K position, GAIN knob at 12 o'clock, pad switch down(for off) and big knob around halfway. On the right side, set the upper little kbnob to PREAMP and the lower little knob to BYPASS(bypassing the compressor section) and check the mic to see if the meter shows a good signal. If not, try upping the small GAIN knob until you do get a solid signal. If you still don't get a good meter reading, it could be a bad preamp section. If you do get a good reading, check it in Protools to see if its getting thru(if not, try another cable or input on the 002 which should be set to +4 on the line inputs bTW). If you are getting a good signal into PT, switch the compressor in(lower small knob, far right). If the signal goes away, that would indicate a bad compressor. Assuming the preamp is new, the dealer should repair or replace it free. It may be a tube was jostled loose in shipping. I hope you get it working as its a great pre and I love mine.
Hooking up Pre to 192 | moonmusic | Pro Tools TDM Systems (Mac) | 9 | 12-17-2013 06:49 PM |
hooking up my RME ADI-2 | WB1984 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-02-2010 03:55 PM |
Hooking up RNC to RNP | Elvisaintme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-30-2003 10:57 PM |
help hooking up a sub | aeugene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-20-2003 02:58 AM |
Hooking up MC-307 to PT anyone? | peneslapepe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-18-2002 11:47 PM |
