Old 06-22-2002, 10:45 AM
lawn_dart lawn_dart is offline
Default Digi Rack Plug Ins Guide
When I try to open the Plug Ins Guide under "Help" in Pro Tools, nothing happens. Any idea how to get this running, or where I can find some basic overviews on the Audio Suite & Plug In functions?
Old 06-22-2002, 10:50 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Digi Rack Plug Ins Guide
Check your Program Files\Digidesign\Pro Tools\Release Notes & Documentation folder and see if your Acrobat pdfs are there. If they won't open, then you need to install Acrobat Reader, linked in the upper right of the Support/Tech Support Technical Document Library section
Administrator
Old 06-22-2002, 10:55 AM
QuikDraw's Avatar
QuikDraw QuikDraw is offline
Digi put the documentation in a folder:
C:\Program Files\Digidesign\Pro Tools\Release Notes & Documentation
All the docs available from the help menu in PTLE must be in that folder to work from the help menu. It seems they goofed. They put the Digirack Plug-ins Guide in a sub-folder inside that folder. If you find the Plug-ins Guide in Windows Explorer and copy it to the above mentioned folder it will then work from the Help menu in PTLE.
Mike
-- Mike
- HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics
- Windows 11 - PT 2021.12
- PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i
- Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs
Old 06-22-2002, 11:36 AM
Avid's Avatar
Administrator
Correct, one more subfolder for the plug-ins docs:
DigiRack docs need to have the following name and location:
In that "Release Notes & Documentation" folder, there should be a folder named:
"Plug-In Notes & Documentation"
and the doc needs to be named:
"DigiRack Plug-Ins Guide.pdf"
(all of these without the " quote marks of course)
Then it should show up in the Help menu.
Administrator
Using Digi Rack plug-in on the 003 in real-time, is this possible? mallanikkelsen Tips & Tricks 4 02-18-2009 06:43 AM
Having toruble with digi 002 rack factory plug-ins bdane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-27-2007 10:17 AM
Digi-Rack plug-ins' effect on sonic qualtiy? imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-11-2002 05:50 PM
Plug in guide ? bengu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-05-2001 07:04 AM
Plug in guide AROOM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-13-2001 09:24 PM
