Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 09-15-2021, 05:41 PM
diogomusique diogomusique is offline
Default Carbon Quality Preamps
hi guys!
i got a carbon and now i'm trying to compare with my latest setup: symphony 2x6 + la610 + isa430.
i can't notice a big difference in quality between the carbon preamps and the ones that i have.
i'm thinking in getting rid of symphony + analog preamps and stay only with carbon.
what do you think?
thanks in advance
Old 09-16-2021, 06:45 AM
darkwavo darkwavo is offline
Default Re: Carbon Quality Preamps
Originally Posted by diogomusique View Post
hi guys!
what do you think?
thanks in advance
Carbon. They’re good. Really good. I have a tree audio branch tube channel for super gourmet things, but the Carbon pres are just as useful at times.
Old 09-17-2021, 11:37 AM
K Roche's Avatar
K Roche K Roche is offline
hi guys!
what do you think?
thanks in advance
Well I have not used my A Designs MP2A since getting the carbon if that says anything ... Or perhaps I am just being lazy
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 09-19-2021, 06:00 PM
Yes, darkwo. I'm actually thinking in keep quality with more convenient workflow. Thanks!
K Roche I hope you're not missing your A Designs
Best for you!
Old 09-19-2021, 07:56 PM
JFreak's Avatar
JFreak JFreak is offline
Once you get past threshold of good enough you cannot hear a difference. There are a lot of documented blind tests out there suggesting you should not worry so much about AD/DA quality unless you plan to use external hardware extensively. Another blind tests say a bad 192kHz converter sounds worse than a god 48kHz converter.
The preamps however, they are either "clean" or made to color the sound in some way. what is "good" for you depends on your priorities. There are many colours available, and some aim for absolutely clear representation of the signal. I myself usually use Focusrite ISA preamps which are on the clean side, being characterised as "neutral" but still have something that says they are worth their price.
As in everything, the closer to the source you go you get bigger gains. Make a better song, find a better artist, have a better day for recording, use a better mic... never worry about the quality of the mic cable so long as it is good enough.
Janne
Old 09-20-2021, 05:59 AM
Thanks, Janne!
Old 09-20-2021, 06:02 AM
K Roche's Avatar
Best for you!
Oh I still have it in my rack just have not used it ..... and no have not missed it
System :
Enjoy the Journey
.... Kev...
Old 09-20-2021, 06:05 AM
I spoke in the sense of missing. you didn't use it because you didn't miss the quality/characteristic sound of it.
Old 09-20-2021, 06:18 AM
K Roche's Avatar
Ah OK , and yes ,correct not missing its sound perhaps because it is on the uncolored side of tube pre amps ?
Now I have not A/B'ed it directly to the Carbons pre's for any particular sound coloration difference....
BUT I did A/B to Carbons pre's for self noise, and found (prototypical to tubes) The MP2A did have a tiny bit more self noise,,,, but honestly only with gain jacked way up and not enough that you would actually notice in real world application with a decent signal going through it and normal gain .........
And given in my work flow as far as mic's, I use a pair of AEA phantom powered ribbons for recording acoustic and electric guitar, and a tube 251 style LDC for vocals so they introduce as much color as I am after in my recordings ,,, which isn't much ...
System :
Enjoy the Journey
.... Kev...
Old 09-20-2021, 11:37 AM
BUT I did A/B to Carbons pre's for self noise, and found (prototypical to tubes) it did have a tiny bit more self noise,,,, but honestly only with gain jacked way up and not enough that you would actually notice in real world application with a decent signal going through it and normal gain .........
Nice!
Carbon with 500 rack- bypassing the preamps / connectivity darkwavo Pro Tools | Carbon 19 06-12-2022 08:09 AM
Sound quality 11R Preamps PT11 remideflon macOS 0 12-02-2013 05:38 AM
quality of MBOX preamps by focusrite 92accordlxtuner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-08-2005 01:57 PM
The Quality of the 002 Converters and Preamps... Keith Owens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-19-2004 03:18 PM
Are the preamps on the mbox good quality? kraaag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-17-2003 12:42 PM
