Old 07-06-2006, 05:09 PM
Drizzman Drizzman is offline
Default DigiTranslator
Hello All,
Everytime I start up PT I get an on screen dialog asking me to authorize DigiTranslator. I'm not sure if it came with PT LE in my Digi 002 Factory Bundle or if I have to buy it. I had to download everything because I use a MacBook Pro so I'm not sure if it was on a disk that I didn't use or what. If I don't own the license to it, what benefits does buying it afford me? Thanks!
Old 07-06-2006, 09:33 PM
Phil Jeffers Phil Jeffers is offline
Default Re: DigiTranslator
Hi, DigiTranslator is essential for any post-production work, as it converts OMF's (Open Media File's) into a Pro Tools session. So, a picture editor will supply the final edit's sync sound (plus temp FX & often final music) via a OMF. DigiTranslator also will convert AAF's which I don't know much about... If you run another system, such as Digital Performer, creating OMF's between projects / sessions is the way to go. They'll save lots of data - fades, volume & other automation. If you want to get rid of the annoying window that pops up, simply delete the plug-in driver from your Library folder and it will bother you no more.
Old 07-08-2006, 02:48 PM
Where can I find that library folder to delete the digitranslator file from? I'm using a MacBook Pro.
Old 07-08-2006, 03:18 PM
JohnnyG JohnnyG is offline
you can search for it with Spotlight...it's a wonderful tool to get use to.
But the file you're looking for should be in Applications>Digidesign>Pro Tools>somewhere in here I believe.
Old 07-08-2006, 03:27 PM
keithaska keithaska is offline
I have the same problem. I can't find digitranslator in my plugins folder. Anyone know what that plugin is called in the plugin folder?
Keithaska
HP Z400 Workstation-
Windows 7 Pro 64 bit
Intel Xeon Quad Core
3.2GHz
8GB Ram
Digi 003R with PT 10.3
Old 07-08-2006, 03:40 PM
It's not in there because it doesn't show up as a "plug-in". Its a .bundle
Old 07-08-2006, 03:43 PM
qpeck qpeck is offline
To get rid of the digitranslator pop up, go into your digidesign folder and delete the OMF.dll or OMF.bundle file.
MacBook Pro 2.0 ghz
1.5 gig RAM
Pro Tools 7.3.1
Digi 002
Old 07-09-2006, 11:39 AM
Tried it...that didn't work. After I did it Protools wouldn't even open. Had to restore the files.
Keithaska
3.2GHz
8GB Ram
Old 07-09-2006, 11:56 AM
Odd. That's what I was told to do the other day, and it worked just fine.
MacBook Pro 2.0 ghz
1.5 gig RAM
Pro Tools 7.3.1
Digi 002
Old 07-09-2006, 12:06 PM
Maybe it was better that you had "restore" Pro Tools. Because Pro Tools functions whether or not Digitranslator is there. I would make sure you did a clean uninstall and reinstall, then everything should be gravy.
digitranslator.......... gdx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-01-2008 12:34 PM
DigiTranslator - What is it? Willosy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-28-2008 06:14 AM
Digitranslator tonejunkee Post - Surround - Video 12 01-07-2008 01:15 PM
Digitranslator 2.0 ????Please Help! Boesch Pro Tools TDM Systems (Mac) 0 07-15-2004 01:50 PM
PT 5.1.3 to DP3, OFM or Digitranslator BPollen Pro Tools TDM Systems (Mac) 1 05-10-2002 08:05 AM
