Old 06-29-2006, 01:01 AM
CoolWhip CoolWhip is offline
Default Popping Problem...
I've recently come across a weird glitch that is driving me insane. When bouncing songs or even playing them back, a very noticeable popping noise can be heard all over the place. It isn't the audio files, because when playing the tune back the pops are different every time. They come whenever i bounce a file and stay for the next ten minutes or so during playback. As soon as i try to bounce the next file, though, they are back for another ten minutes or so. Weird...
I'm running a 2.0 Ghz Macbook with 2GB RAM, and bouncing has never given me any problems in the past. Has anyone else experienced this problem, or (better yet!) know how to fix it? Thanks!
Jordan
Old 06-29-2006, 07:34 AM
Zoejian Zoejian is offline
Default Re: Popping Problem...
Are you running anything digitally into your Digi hardware?
Old 06-29-2006, 08:46 AM
Nope, nothing digitally. I've even removed all of the xlrs and 1/4s running into the box when bouncing, and it still gives the same popping noises...
Old 06-29-2006, 09:24 AM
Bugly Bugly is offline
Are you converting the sample rate or bit depth when you bounce?
If so, are you checking the "Convert after playback" box in the "Bounce to disc" menu?
Definitely sounds like a clock problem....
good luck
Old 06-29-2006, 09:36 AM
DigiTechSupt's Avatar
Have you tried all the steps in the OS X Setup and General Troubleshooting thread yet?
One thing that is suspect would be your RAM - this problem has been reported by other people who have had bad RAM modules.
Avid Audio Tech Support
Support FAQ
Old 06-29-2006, 09:44 AM
No, i'm not converting it at all, just bouncing it in the exact same format (24bit, 88.2khz). Yes, i've gone through the troubleshooting tips, and i've had 2GB of RAM installed for some time now with no problems. I'm only using about 1.3 GB of it, though. The song i'm trying to bounce at the moment only contains nine mono tracks with a few plugins.
Old 06-29-2006, 09:51 AM
I have never run a session at 88.2k
most users I know run at 48k 24Bit
Seeing as the session is not that big... You could try....
"Save session copy in" convert the whole session to 48k
and see how it behaves.... if you could be bothered, that is.
not sure it will fix your prob, but I would try it.
cheers
Old 06-29-2006, 09:53 AM
Shawn Simpson Shawn Simpson is offline
I ran into this problem once with a higher sample rate session. I found that I couldn't get anything to bounce for more than about 3 minutes from a 96k session. To test it, I saved a copy and converted the sample rate down to 48k. From that session, it bounced fine with no pops and clicks. But since I was working with 96k source material I ended up just using the old "bounce to an audio track" method, then exported the region as a file.
***and for what it's worth I tested the sound of the recorded file and the bounced file and the only sonic difference were the pops and clicks, complete cancellation when phase reversed otherwise***
Old 06-29-2006, 10:48 AM
Which Digidesign hardware are you using? What type of drive are your audio files on?
Support FAQ
Old 06-30-2006, 01:12 AM
002R, and my files are stored on a seagate 300gb external drive that is daisy-chained firewire to the interface.
Stutter effect popping problem Danny Winn Tips & Tricks 6 09-08-2013 12:40 PM
Constant popping and Amplitube problem please help ganderpander macOS 1 05-15-2012 01:29 PM
ok... wtf? playback engine, and buffer size, crack/popping problem.. but weirder oosurf08oo Pro Tools M-Powered (Win) 1 12-06-2009 02:42 PM
Popping!! themachinesneverdie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-19-2006 10:27 AM
big problem-popping sound in audio jmallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2004 09:04 AM
