Old 10-11-2021, 04:10 PM
soundartsonline soundartsonline is offline
Default Double attack notes/ Sample Tank 3/ ISSUE SOLVED
So.... in general, here's the work around this issue that I've found. Shorten the note's value and the double attack effect disappears. I'm guessing the samples are trying to loop if the value is too long in time. This is a programming/sampling issue and the midi notes don't adapt well to longer values than an 8th or 16th at times. This can be problematic when trying to write a legato phrase connecting say a quarter note to the next, if that particular note decides to do the double attack. I'll update you when/if I find other solutions. Doesn't happen with every sampled sound in Sample Tank 3.
I'm sure I can't be the only one encountering this issue.
Hey everyone! I'm using Protools 12/ High Sierra/ iMac.
Anyway, I've encountered this issue here and there with Sample Tank 3. Using a nylon guitar patch, recording instrument as midi. Depending on where the note is played (or moved in the midi editor) I can sometimes hear a double note (sounds like one 1/16th note prior to the next ,when there is clearly only 1 midi note there. If I move the note around the double effect goes away.
Any thoughts as to how I can get rid of the double note?
Thanks!
Lisa
Old 10-16-2021, 09:58 AM
Default Re: Double notes Sample Tank 3
How are you recording the notes?
Old 10-17-2021, 05:15 PM
I am recording the notes as midi while playing a keyboard (controller). Have a track set up as midi with Sample tank on the Aux track. Using the assigned channel on the track, same setup as usual.
double notes john1192 MIDI 0 04-17-2007 09:03 AM
Double Notes!!!! roziel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-02-2007 10:30 PM
Sample Tank 2 Xl conbreaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-04-2005 05:07 PM
another sample tank bug? rogga_bogga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-25-2003 12:05 PM
Sample Tank..How? Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-04-2002 01:27 AM
