Old 09-23-2021, 04:13 AM
ilmalvaggio ilmalvaggio is offline
Default Carbon+Ferrofish level matching
Hello, I have a "problem" of level matching between my two converters. I have a brand new Avid Carbon and a Ferrofish A16 AE converter. At +4dbu level setting on both converters the Ferrofish "sounds" lower than the Carbon. I made a test with a 1khz tone feeding two pair of outputs on thew two converters going straight in the the input of the Carbon (no patchabay in the path). The result is about -4dbfs for the Ferrofish. If i switch The Carbon outputs to -10dbv they match. I'm a little bit confused. Any idea?
Thank you.
Fulvio
Old 02-08-2023, 10:52 PM
scremedy scremedy is offline
Default Re: Carbon+Ferrofish level matching
Hello. Did you resolve this issue? I ask as I’m looking to expand my carbon and the Ferro fish seems like the best solution to get 16 I/O. I do notice they sell a version w +24 db option, which sounds like it would solve your issue.
My question to you is are you able to get 8 ch per adat port out of the Ferro fish or only 4 per port? Thanks
Old 02-08-2023, 11:20 PM
Yes, I solved. I sold the Ferrofish. Ahahaha. Seriously it wasn’t a real issue for me as I didn’t need to feed o receive signals from an hardware like a summing mixer that probably would benefit from an equal signal
My studio setup changed as I don’t need 24 I/O anymore.
By the way you can get 16 channels (8+8) @ 44.1 and 48 and 8 (4+4) @ 88.2 ana 96 khz. You have to set the second pair of optical ports on the Corbon to Adad mode to achieve full configuration.
Old 02-09-2023, 12:08 PM
eightamrock eightamrock is offline
I have a ferrofish pulse 16, its great!. I dont have any leveling issues. With everything set to 0 on the FF, it matches the +4 settings on the carbon excatly. When I set up my rig, I sent a signal generator through it and all sends/returns were identical between the units.
The pulse is tricky because you actually have a LOT of flexibility with the routing, the limiting factor is actually the carbon.
Carbon has 2 adat in and out. Which supports a max of 16 channels at 44.1 and 48k, OR 8 channels at 96k+ over smux (2 adat channels paired)
The pulse actually supports 32 channels of adat across 4 banks. Only 16 of them can be routed to analog i/o at any given time. The pulse can do 16 channels of 96k+ adat by useing 2 banks of 8 adat on smux (all 4 adat banks).
If in the future, they unlock the capability to use adat on a carbon pre you could then pipe the other 8 channels of smux at 96k through that unit giving you 32 channels for 96k + into pro tools. (8 carbon, 8 carb pre, 16 ferrofish)
Personally I have 2 adat preamps that I plug into the extra adat in ports on the pulse and then i have 3 presets in the pulse to change the routing around for tracking when I want to use the preamps, and mixing where I use my outboard gear.
Hope this helps!
Old 02-10-2023, 06:58 AM
That’s great information. Thanks much. I did actually order a Pukse w the +24dB modification, mainly because I own a post production company and just future proofing it in case I need to put this working in that world where everything is +4. Looking forward to getting it.
Since you are doing what I hope to do - expanding the carbon, may I ask what patchbay you’re using and are you doing anything with the db25 8 channels output/input connections? Thank you
Ferrofish Pulse 16 Interfaces Question. ramonetl Third Party Interfaces 6 12-29-2023 01:37 AM
Replacing a Clip with a Matching Segment from a Matching Field Recorder Channel srdm77 Pro Tools 2020 6 12-31-2020 01:22 AM
Can I use a Ferrofish A16 (16-channel digital I/O) with a 192? firmflange Pro Tools HDX & HD Native Systems (Mac) 7 11-22-2017 09:23 PM
Matching MixBus level with track channel during calibration. ODC Pro Tools TDM Systems (Mac) 0 02-26-2002 10:51 AM
Level matching problem andre tchmil Pro Tools TDM Systems (Mac) 0 04-19-2001 12:39 AM
