Old 03-26-2011, 12:02 AM
Stiv Stiv is offline
Default PT9 Crossgrade (License) not working - RESOLVED
Hi I'm new to the forum so hello to all!
I've just upgraded from Pro tools 8le to Pro tools 9.
I went to the activation page (in Avid) and entered my PT9.0 LE Crossgrade Activation Code.
I then hit download and was sent to the ILok website as per norm.
Ilok tells me there is no license from avid to put on my ilok in the computer.
So of course PT9 won't work.
My ilok has 6 licenses on it from the expansion pack i purchased so i have done the proceedure correctly before with no probs.
Any suggestions?
Stiv
Win 7 (64)
Old 03-26-2011, 01:43 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: PT9 Crossgrade (License) not working
I don't see the activation/registration in your online registration records or your Avid account, so I'm not sure what the problem might be.
Try logging into your Avid account at http://account.avid/com
Then clicking on Activate & Download Your Product
Enter your activation code, and if it has not already been used, you should be taken to the next screen where you would enter your iLok User ID and your serial number from the back or bottom of your LE hardware.
You would need to complete those steps before completing the registration process.
Administrator
Old 03-26-2011, 05:35 AM
Thanks for your reply
I've tried that a few times
I should have given more info... i bought pro tools 8le about 6 weeks ago.
Every time ive tried to put in the activation code for it (in avid's activation page), it won't accept it tellimg me i must have the wrong code.
I've checked and double checked and had others confirm that the numbers (all "0" characters are zeros) and the case sensitive letters are correct. It still won't accept it. At least i could still use the software.
Could this be the reason my now pro tools 9 activation won't go through? because it's a crossgrade and i need pt8 registered first?
Cheers
Stiv
Old 03-26-2011, 05:40 AM
i noticed the PT8LE Activation code has spaces between the 3 sets of 8 digits.
Yet the activation page shows a dash between the digits as an example.
What the hell. I tried it with the dashes and that doesn't work either.
Any help would be appreciated.
Stiv
Old 03-26-2011, 06:24 AM
nst7 nst7 is offline
What Protools LE hardware do you have? You need the serial number from the hardware to make this work. It's an upgrade based on having the hardware, not the old software. The Avid guy mentioned this, but I don't know if you caught it.
Old 03-26-2011, 05:42 PM
Avid's Avatar
Administrator
You are trying to enter the wrong code. You are confusing your Pro Tools LE 8 Authorization Code (serial number to run PTLE software) with your Pro Tools 9 upgrade ACTIVATION CODE.
If you purchased the Pro Tools LE to Pro Tools 9 Crossgrade, you would have received an activation code with the upgrade. Look through everything that came with your upgrade, either a printed activation code if you bought a boxed version, or on your order receipt if you purchased a download-only version.
Enter the Activation Code that came with your upgrade, and begins with "PT9LEU...." in the activation area of the website.
If your Activation Code does not work for some reason, then you need to contact Avid Customer Support and provide them with the exact Activation Code that you have so they can investigate, along with a copy of your receipt from an Avid authorized dealer. If you purchased from someone other than an authorized dealer, then you are on your own, and need to contact the seller to work it out.
If you cannot find an Activation Code at all, then you need to contact the dealer where you purchased the upgrade.They may have sent it to you in an email receipt or online confirmation that you did not receive, or some other explanation.
Administrator
Old 03-26-2011, 09:42 PM
Thanks for your reply.
No i wasn't using the wrong code.
Since i've had pt8,the avid page would not accept that code but the software worked so i didn't worry about registering.
Now i have PT9, when i put in the PTLEU etc it sends me to the ilok website after hitting "download" but when i get there, there's no license to transfer to my ilok.
Obviously i'm doing something quite wrong because it makes no sense that out of the three sets of software i have purchased (PT8-Expansion Pack-PT9 Crossgrade), only one is recognized by the Avid website.
This is a legit purchase so i was hoping to avoid having to pay for support that i can only access at midnight in Australia.
Thanks again
Stiv
Old 03-26-2011, 09:46 PM
Yes Thanks. You are correct i did not read it properly.
I'll try that
Stiv
Didn't have to do it that way for the Expansion software licenses.
Sure gonna feel like a klutz if it works.
Old 03-26-2011, 10:20 PM
TOM@METRO's Avatar
We all feel like a klutz now and then, maybe it's just your turn.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-26-2011, 10:45 PM
Hello...... Klutz Here!
Thanks for that Tom. Yes it's my turn.
\\\ IT WORKS \\\ (but you all knew that darn it)
Thanks all for your help.
As we say in OZ... "Let me explain to you how to spell [bleep][bleep][bleep][bleep][bleep][bleep][bleep][bleep]"
Humble pie doesn't taste so bad when the result is good.
Hopefully my stupidity will help prevent others from a similar embarrassment.
I guess that's what forums are partly for.
Thanks again and CHEERS!
Stiv
Will I get PT10 license with crossgrade from LE? RabidPickle Pro Tools 11 1 07-19-2013 06:11 PM
RESOLVED: Is it just me? On/Off Axis not working? vinceh Eleven Rack 2 03-24-2011 03:27 PM
PT9 Crossgrade and IE pack License pfornell Pro Tools 9 0 02-19-2011 10:42 PM
ProTools HD 9 License Crossgrade Info leftbrain Pro Tools 9 1 11-06-2010 11:22 AM
