Old 11-02-2006, 10:14 AM
Stoneroses63 Stoneroses63 is offline
Default problem when mixing drums to its own stereo channe
I was mixing all my 12 drum tracks for a song to its own seperate stereo channel..THen I was going to make the other drum track inactive to free up tracks...But when I did this, the stereo drum track that I bounced to the drums too, didnt line up with the rest of the tracks...I think it was a little bit slow compared to the rest of the tracks...ANyone know whats going on with this? Thank you
Old 11-02-2006, 10:59 AM
Naagzh Naagzh is offline
Default Re: problem when mixing drums to its own stereo channe
Some plug-ins have a built-in latency that you can compensate for by nudging that track back in time by the same amount. For example, to insert PSP VintageWarmer on a snare track, nudge the snare track back by 511 samples (that's the amount of delay that VW causes). To see how much delay a plug-in has, control-click below the fader (where the fader position is displayed). Take careful notes of how much you shift any track.
By the way, what you're doing is referred to as "printing". You're printing a submix (of drum tracks) to an available stereo audio track. Bouncing to disk is almost identical, except that PT is using slightly more sophisticated maths to do the conversion. In the absence of all plug-ins, there shouldn't be a single sample of delay between a submix printed within PT and the original tracks.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 11-02-2006, 01:42 PM
Come to think of it, I think I had the PSP master comp on my submix of drums...I already erased it...Does this have a latency issue?
Ok, I found how much delay it has...Now how do I nudge a track back in the exact amount of delay?
Old 11-02-2006, 07:29 PM
x9blade x9blade is offline
go to the grid and nudge value display ,kind of towards the top left center of the edit window. hit the nudge drop down and select samples>type the amount in that field. the amount you discovered on your drum track.important ,hit enter after you entered the latency amount. now select your drum region and press the minus key on your num pad and you should see your region slide back the correct amount. that is if your zoomed in enough. good luck
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 11-03-2006, 06:54 AM
Highlight the region, then Edit -> Shift. Enter in the number of samples. Won't work if you're in grid mode.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 11-03-2006, 07:03 AM
This sounds easier. Ha, Thank you
Old 11-03-2006, 01:15 PM
i think alt h also works. if your looking for easy
Surround Mixing / Stereo monitoring with Soundcode Stereo Meads Post - Surround - Video 6 01-04-2011 04:52 AM
Mixing BFD drums mdo9 The Drum Room 2 10-30-2009 09:29 AM
Mixing drums using stereo aux johnwayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-11-2006 08:13 AM
Drums in stereo calibos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2006 12:21 PM
connecting 001 to a home stereo to A/B between mixing monitors and stereo speakers... Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-09-2003 11:14 PM
