Old 01-28-2005, 11:55 AM
keithl keithl is offline
Default stereo or mono reverb for drums? whats the norm?
Since getting the PT/002 system, I finally have enough tracks to do what I want (ok, always could use more!), but...
when you guys mix down drums, do you give the snares and toms a stereo reverb or mono (pros/cons). I always used mono, but was thinking about it more last night. My thought process is that the stereo reverb would just be cluttering things up...alas, I could be wrong!
How about instruments?
what do you usually use...stereo or mono?
Old 01-28-2005, 12:00 PM
Third Eye Studios Third Eye Studios is offline
Default Re: stereo or mono reverb for durms? whats the norm?
Mono in, stereo out is usually what I do, with drums and instruments.
Old 01-28-2005, 12:14 PM
when you say out...each drum? snare = stereo, left tom = stereo, right tom = stereo?
Old 01-28-2005, 12:47 PM
nightshadecrisis nightshadecrisis is offline
i try to group and send to verbs, so for instance left and right tom will go to the same reverb. i rarely put any reverb on anything other than toms and a bit of plate reverb for snare. sometimes i'll send all the drums lightly to a room reverb. almost all of the reverbs i put on things are stereo.
ev
ik zei nooit dat!
Old 01-28-2005, 12:56 PM
Default Re: stereo or mono reverb for drums? whats the norm?
Using Sends and Returns
Create an audio track.. say for your vocal.. name it "VOX", create a mono Aux Track for your Reverb.. name it "REVERB".
Switch to your Mix Window and in the Display menu select Mix Window Shows... and select All.
In the Mix window you have 5 buttons in the top section for your 5 inserts.. below that you have 5 buttons for your sends.. For the track named "VOX", using the first send button create a post fader send to Buss 1. A small window with a send fader will appear on the screen. Keep the output of the track "VOX" set to your stereo buss which is usually Outputs 1&2. Set the input of your track named "REVERB" to the same buss you selected (Buss 1).. keep the output of the "REVERB" track set to Outputs 1&2.
Control + click (Command +click on a Mac) on the solo button of the Aux track, "REVERB", to solo isolate it.
Instantiate a (mono/stereo) reverb on your Aux track, "REVERB" and set it to 100% wet.
Set the Aux Fader ("REVERB") to zero (Alt click on it - Option click on a Mac).
You can now use the send fader to send signal from your "VOX" track to your "REVERB". Because the send is post fader the sent signal is in relation to any rides you do on your vocal track.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-28-2005, 01:16 PM
asa asa is offline
Typically I use a stereo reverb for all sources, whether they be mono or stereo. Also, I try not to use too many reverbs, this can make your track seem unnatural and also make it hard to make the instruments sound cohesive. Set up your scenario using sends and returns, like in the instruction left by Rail. You can control panning to the Reverb, if you find that is needed, from within the Send Window, the same window that has the fader used to control the amount of level you send from the source track to the reverb. It has pan sliders that work the same as the Pan Sliders on audio or aux tracks.
Asa Doyle
Groove 3 Inc.
www.groove3.com
Old 01-28-2005, 02:31 PM
homerg homerg is offline
For drums, I "send" the stereo overhead tracks to an stereo AUX track which has a stereo reverb as a plug-in. Sometimes I add extra reverb to the snare by sending it to the same bus. I don't like a lot of reverb on drums, but that's probably because my room is very natural and bright sounding. I guess if you have a very dead sounding room you would probably need more reverb to bring the drums back to life a bit. Just experiment with the options detailed above.
ASUS A7N8X-E Deluxe
MD Athlon XP3200+2.20GHZ
Corsair XMS PC3200 400MHZ 1GB
WD EIDE 10GB
WD EIDE 250GB
XP Pro SP1
ProTools LE 6.4
Old 01-28-2005, 03:43 PM
neomodo neomodo is offline
Question about this reply -
If I create a mono Aux channel - when selecting the input (from the VOX send) It asks me to select either the left of the right channel... that seems odd... Is this a question of setting my IO for the bus to be a stereo bus with no mono (L & R) specifications? That seems odd too... And I suppose that the send from the VOX channel should be set to send out to the stereo bus right?
Obviously I'm a little confused but I just happen to be playing around with sends setup when I saw this post...
thanks
Old 01-28-2005, 03:47 PM
Well.. your actual Vocal track should be a mono track -- there's very seldom any reason to place any effect directly across a mono track which changes the track into a stereo track. Use Sends and Returns for effects... use inline inserts only for correction type devices like EQ and compression.
Rail
Platinum Samples
Old 01-28-2005, 03:56 PM
What I did was go to the IO settings and deleted the Bus I had (FX Send 1) with to subs (L & R) and recreated it w/out the sub paths and just told it to be a mono bus. I'm sure this is wrong. My Vox track IS a mono track but in the send to option it gave me the option to send to FX Send 1 stereo or FX Send 1 L and FX Send 1 R - I'm sure it probably won't matter all that much either way but with the IO change I mention above it simple didn't give me the left and right option when it came time to set it for the Reverb channel - I'm probably just being pedantic.
thx
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
Need advice on when to use mono vs. stereo reverb TFL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-01-2007 11:08 PM
Stereo vs. mono reverb John Link General Discussion 8 11-16-2005 11:52 AM
Bussing reverb - stereo or mono? MidnightFlyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-16-2003 02:34 AM
bouncing:goes mono,only reverb stays stereo.WHY? odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-18-2001 12:19 AM
