Old 05-14-2021, 07:08 AM
pk.roberts pk.roberts is offline
Default ProTools & Big Sur
Howdy Folks,
Is anyone successfully running ProTools Ultimate (with Local iLok) on an Intel Mac running Big Sur at the moment? The Avid website claims versions post 2021.3 are supported;
https://avid.secure.force.com/pkb/artic ... ur-Support
We are using the latest build, but on testing this we are experiencing instances of failure to launch and/or crashing. We have also tested an install without plug-ins and try and narrow this down a bit, but with no improvement; (almost) any thoughts, advice or experiences welcome.
Thanks in advance.
Old 05-14-2021, 10:55 AM
paul_g's Avatar
paul_g paul_g is offline
Default Re: ProTools & Big Sur
System specs? https://duc.avid.com/showthread.php?t=300050
Have you tried trashing prefs?
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 05-14-2021, 11:45 AM
dankin dankin is offline
I'm running 2020.11 on the latest version of Big Sur. I get some occasional crashes when opening sessions, but otherwise it's stable.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII
Old 05-14-2021, 12:42 PM
paul_g's Avatar
2021 is the supportable version with Big Sur:
https://avid.secure.force.com/pkb/ar...tibility-Chart
2020 will probably work, but as you said, you're seeing issues.
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Old 05-15-2021, 02:08 PM
DerrickC DerrickC is offline
Have you experienced any graphics lag or any problem with PT 2021.3.1 on macOS 11.3.1? I read somewhere else that there may be such problem, so I wanna see if it’s really any issue before updating my macOS. Thanks!
Old 05-15-2021, 05:51 PM
Eric Lambert's Avatar
Latest versions of PT and Big Sur here -- it's all relatively stable. No graphics issues that are related to PT directly, though a couple plugins will lag when I enlarge their GUI.
Old 05-15-2021, 06:04 PM
GoButtonGuy GoButtonGuy is offline
All good here. Check whatever non Avid plugs and VIs you use to make sure they are compatible with Big Sur.
What happens in Vegas, we make happen...
Old 05-15-2021, 06:47 PM
gives's Avatar
gives gives is offline
Originally Posted by pk.roberts View Post
Howdy Folks,
Thanks in advance.
It's supported but not ready for prime time according to several higher up Avid
product specialists. They told me to NOT update to it unless I have no choice. I have been running my studio on major projects with Mojave for a couple of years and now just updated to Catalina and was surprised how seamless the update went. I am sure you are in a different position that myself, so maybe that is a have to situation. I know some people went back to Catalina, but not sure it's always possible.
The cpu spikes I would get occasionally are gone.
Only thing I miss is QT Pro 7, which kind of killed a way to bounce movie without problems. I figured out a workaround for me which I did a thread on. Forwarded the info to Avid, since a lot of users were still having trouble. It's only a problem for people in Movie Bounce and selecting just sections. It works from the front of the movie however without crashing.
Good luck with it all-:)
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 05-17-2021, 10:57 AM
Losing QT7 Pro was a major bummer here, initially, but I've grown to prefer QT X. Dragging a bounced audio file into the movie is a breeze. It's an extra step (albeit a quick one), but I feel better not letting PT touch the video file.
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! G ray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2011 07:09 PM
Sending protools projects to other protools users online kdtufan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2008 07:18 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
